Thanks a lot for all the great work that you guys put into making Ubuntu Mate a very good OS, I have been using Ubuntu Mate for the past few years without any issues but the latest version 16.10 is giving me trouble. Every time I turn my laptop on, my screen goes black for a few minutes then, I get a message about a dev file cleaning and sometimes my laptop reboots and I get another message about a recovery journal or something like that. I have waited more than 5 minutes, dark screens and a few reboots until I get to the login screen. I never had this issue before with the previous Ubuntu Mate versions, Can I get rid of this cleaning and recovering journal so when I turn my laptop on I get to the login screen?
Thank you very much in advance for your reply and for making Ubuntu Mate a very good user friendly and free OS.
Best Regards,
Daniel
Hi @bddiaz,
have you run your updates?:
Hello Daniel,
First off it is NOT normal that your laptop reboots in loop like that. Actually, when a filesystem is done cleaning up by the fsck program it should resume it’s regular booting.
Therefore it your laptop just refuses to colaborate I am ready to bet it’s because there is a physical issue with it, most probably with the hard drive.
Do you ever manage to have your system booted into a “stable” state? (One that allows you to write commands in it?) If so, open a terminal (CTRL+ALT+T) and type “dmesg”. Possibly some errors will pop-up. In doubt, feel free to paste the entire output here.
Cheers,
If you find that it is your hard drive causing the problems, I recommend that you run Spinrite on it.
Hey @mrjoeyman
Ewwww @ Spinrite. That’s commercial software
https://www.grc.com/cs/prepurch.htm
I would rather go for dcfldd which a dd enhancement which will put all the stress needed on your device.
Cheers,
Yes and well worth it
Hi guys,
Thanks a bunch for your posts. I will try it during the weekend and post the outcome here. I doubt that this is a hardware issue, for me, the issue is with the software. I have a dual boot Windows 7 Starter and Ubuntu Mate 16.10. Windows 7 boots fine, even when I was on Ubuntu Mate 15.10, the laptop worked fine, no issues at all like the one I am having with 16.10.
I am able to get into Ubuntu since eventually the system doesn’t do the cleaning or the recovery journal and then I am able to login. When I get the dark screen and the rebooting, I press the power bottom, shut the computer down and then the next time, I go into the login screen. However, it is kind of annoying to do this pretty much everyday, this a lot more often that I would like or chose to.
I have updated 16.10 and the issue remains. I even went back to 15.10 and it was fine, no problem, I just updated to 16.10 because there isn’t any more support for 15.10. We’ll figure out what’s the issue with my laptop, it is hard to go back to Windows 7 Starter after getting used to Ubuntu Mate.
Later
During the weekend I reinstalled 16.04 32 bit, which according to the Ubuntu Mate download website is the one I should have and not the 64 bit amid my 2GB of RAM. I have booted many times in Ubuntu without problems. Anyway, I typed “dmesg” and the results are below. I don’t understand the outcome of "dmesg"that much so please let me know if there is anything weird. I tried with dcfldd but it took a while and since I didn’t get anything on the terminal for a at least 10 minutes, I closed the terminal.
[ 0.458054] pci_bus 0000:02: resource 1 [mem 0x82000000-0x82ffffff]
[ 0.458061] pci_bus 0000:02: resource 2 [mem 0x81000000-0x81ffffff 64bit pref]
[ 0.458068] pci_bus 0000:03: resource 4 [io 0x0000-0x0cf7 window]
[ 0.458074] pci_bus 0000:03: resource 5 [io 0x0d00-0xffff window]
[ 0.458080] pci_bus 0000:03: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.458087] pci_bus 0000:03: resource 7 [mem 0x000c0000-0x000dffff window]
[ 0.458093] pci_bus 0000:03: resource 8 [mem 0x000e0000-0x000effff window]
[ 0.458099] pci_bus 0000:03: resource 9 [mem 0x000f0000-0x000fffff window]
[ 0.458106] pci_bus 0000:03: resource 10 [mem 0x7f800000-0x7fffffff window]
[ 0.458112] pci_bus 0000:03: resource 11 [mem 0x80000000-0xfebfffff window]
[ 0.458187] NET: Registered protocol family 2
[ 0.458609] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.458657] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.458716] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.458770] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.458789] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.458910] NET: Registered protocol family 1
[ 0.458955] pci 0000:00:02.0: Video device with shadowed ROM
[ 2.059791] pci 0000:00:1d.7: EHCI: BIOS handoff failed (BIOS bug?) 01010001
[ 2.060087] pci 0000:01:00.0: set MSI_INTX_DISABLE_BUG flag
[ 2.060102] PCI: CLS 64 bytes, default 64
[ 2.060262] Trying to unpack rootfs image as initramfs...
[ 3.691434] Freeing initrd memory: 36092K (f3972000 - f5cb1000)
[ 3.691950] Scanning for low memory corruption every 60 seconds
[ 3.692948] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 3.693020] audit: initializing netlink subsys (disabled)
[ 3.693056] audit: type=2000 audit(1478513917.556:1): initialized
[ 3.693888] Initialise system trusted keyring
[ 3.694230] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 3.699314] zbud: loaded
[ 3.699642] VFS: Disk quotas dquot_6.6.0
[ 3.699803] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 3.700600] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 3.701451] fuse init (API version 7.23)
[ 3.701964] Key type big_key registered
[ 3.702026] Allocating IMA MOK and blacklist keyrings.
[ 3.703781] Key type asymmetric registered
[ 3.703792] Asymmetric key parser 'x509' registered
[ 3.703848] bounce: pool size: 64 pages
[ 3.703982] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 3.704131] io scheduler noop registered
[ 3.704139] io scheduler deadline registered (default)
[ 3.704247] io scheduler cfq registered
[ 3.705383] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 3.705408] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 3.705506] vesafb: mode is 800x600x32, linelength=3200, pages=0
[ 3.705510] vesafb: scrolling: redraw
[ 3.705517] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 3.705558] vesafb: framebuffer at 0x7f800000, mapped to 0xf8600000, using 1920k, total 1920k
[ 3.705865] Console: switching to colour frame buffer device 100x37
[ 3.705900] fb0: VESA VGA frame buffer device
[ 3.705958] intel_idle: MWAIT substates: 0x3020220
[ 3.705963] intel_idle: v0.4.1 model 0x36
[ 3.705967] intel_idle: lapic_timer_reliable_states 0xffffffff
[ 3.706640] ACPI: AC Adapter [ADP0] (on-line)
[ 3.706849] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 3.706860] ACPI: Power Button [PWRB]
[ 3.706996] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input1
[ 3.709330] ACPI: Lid Switch [LID0]
[ 3.709478] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 3.709487] ACPI: Power Button [PWRF]
[ 3.715011] thermal LNXTHERM:00: registered as thermal_zone0
[ 3.715019] ACPI: Thermal Zone [TZ01] (26 C)
[ 3.715114] GHES: HEST is not enabled!
[ 3.715314] isapnp: Scanning for PnP cards...
[ 3.715477] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 3.717313] ACPI: Battery Slot [BAT0] (battery present)
[ 3.721613] Linux agpgart interface v0.103
[ 3.736821] brd: module loaded
[ 3.741516] loop: module loaded
[ 3.742247] libphy: Fixed MDIO Bus: probed
[ 3.742256] tun: Universal TUN/TAP device driver, 1.6
[ 3.742260] tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
[ 3.742423] PPP generic driver version 2.4.2
[ 3.742616] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.742632] ehci-pci: EHCI PCI platform driver
[ 3.742894] ehci-pci 0000:00:1d.7: EHCI Host Controller
[ 3.742914] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 3.742941] ehci-pci 0000:00:1d.7: debug port 1
[ 3.746866] ehci-pci 0000:00:1d.7: cache line size of 64 is not supported
[ 3.746904] ehci-pci 0000:00:1d.7: irq 17, io mem 0x84105000
[ 3.755770] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 3.755918] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.755925] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.755931] usb usb1: Product: EHCI Host Controller
[ 3.755937] usb usb1: Manufacturer: Linux 4.4.0-45-generic ehci_hcd
[ 3.755942] usb usb1: SerialNumber: 0000:00:1d.7
[ 3.756362] hub 1-0:1.0: USB hub found
[ 3.756388] hub 1-0:1.0: 8 ports detected
[ 3.757303] ehci-platform: EHCI generic platform driver
[ 3.757350] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 3.757367] ohci-pci: OHCI PCI platform driver
[ 3.757408] ohci-platform: OHCI generic platform driver
[ 3.757439] uhci_hcd: USB Universal Host Controller Interface driver
[ 3.757664] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 3.757682] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 3.757699] uhci_hcd 0000:00:1d.0: detected 2 ports
[ 3.757739] uhci_hcd 0000:00:1d.0: irq 17, io base 0x000040a0
[ 3.757904] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.757911] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.757917] usb usb2: Product: UHCI Host Controller
[ 3.757923] usb usb2: Manufacturer: Linux 4.4.0-45-generic uhci_hcd
[ 3.757928] usb usb2: SerialNumber: 0000:00:1d.0
[ 3.758319] hub 2-0:1.0: USB hub found
[ 3.758344] hub 2-0:1.0: 2 ports detected
[ 3.758880] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 3.758899] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 3.758919] uhci_hcd 0000:00:1d.1: detected 2 ports
[ 3.758983] uhci_hcd 0000:00:1d.1: irq 19, io base 0x00004080
[ 3.759146] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.759154] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.759160] usb usb3: Product: UHCI Host Controller
[ 3.759166] usb usb3: Manufacturer: Linux 4.4.0-45-generic uhci_hcd
[ 3.759171] usb usb3: SerialNumber: 0000:00:1d.1
[ 3.759558] hub 3-0:1.0: USB hub found
[ 3.759582] hub 3-0:1.0: 2 ports detected
[ 3.760166] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 3.760185] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 3.760200] uhci_hcd 0000:00:1d.2: detected 2 ports
[ 3.760255] uhci_hcd 0000:00:1d.2: irq 18, io base 0x00004060
[ 3.760421] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.760428] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.760434] usb usb4: Product: UHCI Host Controller
[ 3.760440] usb usb4: Manufacturer: Linux 4.4.0-45-generic uhci_hcd
[ 3.760445] usb usb4: SerialNumber: 0000:00:1d.2
[ 3.760835] hub 4-0:1.0: USB hub found
[ 3.760860] hub 4-0:1.0: 2 ports detected
[ 3.761384] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 3.761403] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[ 3.761418] uhci_hcd 0000:00:1d.3: detected 2 ports
[ 3.761473] uhci_hcd 0000:00:1d.3: irq 16, io base 0x00004040
[ 3.761634] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.761642] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.761647] usb usb5: Product: UHCI Host Controller
[ 3.761653] usb usb5: Manufacturer: Linux 4.4.0-45-generic uhci_hcd
[ 3.761659] usb usb5: SerialNumber: 0000:00:1d.3
[ 3.762048] hub 5-0:1.0: USB hub found
[ 3.762072] hub 5-0:1.0: 2 ports detected
[ 3.762619] i8042: PNP: PS/2 Controller [PNP0303:KBC,PNP0f13:MOUE] at 0x60,0x64 irq 1,12
[ 3.790765] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 3.790783] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 3.791263] mousedev: PS/2 mouse device common for all mice
[ 3.791935] rtc_cmos 00:03: RTC can wake from S4
[ 3.792220] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[ 3.792273] rtc_cmos 00:03: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 3.792299] i2c /dev entries driver
[ 3.792482] device-mapper: uevent: version 1.0.3
[ 3.792712] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: [email protected]
[ 3.792796] platform eisa.0: Probing EISA bus 0
[ 3.792805] platform eisa.0: EISA: Cannot allocate resource for mainboard
[ 3.792811] platform eisa.0: Cannot allocate resource for EISA slot 1
[ 3.792817] platform eisa.0: Cannot allocate resource for EISA slot 2
[ 3.792823] platform eisa.0: Cannot allocate resource for EISA slot 3
[ 3.792829] platform eisa.0: Cannot allocate resource for EISA slot 4
[ 3.792835] platform eisa.0: Cannot allocate resource for EISA slot 5
[ 3.792841] platform eisa.0: Cannot allocate resource for EISA slot 6
[ 3.792847] platform eisa.0: Cannot allocate resource for EISA slot 7
[ 3.792853] platform eisa.0: Cannot allocate resource for EISA slot 8
[ 3.792858] platform eisa.0: EISA: Detected 0 cards
[ 3.792900] cpufreq-nforce2: No nForce2 chipset.
[ 3.792925] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.793711] NET: Registered protocol family 10
[ 3.794424] NET: Registered protocol family 17
[ 3.794463] Key type dns_resolver registered
[ 3.795188] microcode: CPU0 sig=0x30661, pf=0x8, revision=0x10d
[ 3.795215] microcode: CPU1 sig=0x30661, pf=0x8, revision=0x10d
[ 3.795233] microcode: CPU2 sig=0x30661, pf=0x8, revision=0x10d
[ 3.795290] microcode: CPU3 sig=0x30661, pf=0x8, revision=0x10d
[ 3.795416] microcode: Microcode Update Driver: v2.01 <[email protected]>, Peter Oruba
[ 3.795445] Using IPI No-Shortcut mode
[ 3.795980] registered taskstats version 1
[ 3.796019] Loading compiled-in X.509 certificates
[ 3.805355] Loaded X.509 cert 'Build time autogenerated kernel key: 269c8541c5a984b2610c4e64b4663aeac53a1fa7'
[ 3.805420] zswap: loaded using pool lzo/zbud
[ 3.811806] Key type trusted registered
[ 3.824022] Key type encrypted registered
[ 3.824043] AppArmor: AppArmor sha1 policy hashing enabled
[ 3.824052] ima: No TPM chip found, activating TPM-bypass!
[ 3.824110] evm: HMAC attrs: 0x1
[ 3.824715] Magic number: 8:885:324
[ 3.824783] tty tty49: hash matches
[ 3.824826] acpi PNP0B00:00: hash matches
[ 3.824919] rtc_cmos 00:03: setting system clock to 2016-11-07 10:18:38 UTC (1478513918)
[ 3.827094] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 3.827099] EDD information not available.
[ 3.827323] PM: Hibernation image not present or could not be loaded.
[ 3.830162] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[ 4.026642] isapnp: No Plug & Play device found
[ 4.027552] Freeing unused kernel memory: 940K (c1b89000 - c1c74000)
[ 4.027885] Write protecting the kernel text: 7896k
[ 4.028007] Write protecting the kernel read-only data: 3140k
[ 4.028011] NX-protecting the kernel data: 6440k
[ 4.064590] random: systemd-udevd: uninitialized urandom read (16 bytes read, 0 bits of entropy available)
[ 4.064901] random: systemd-udevd: uninitialized urandom read (16 bytes read, 0 bits of entropy available)
[ 4.066647] random: udevadm: uninitialized urandom read (16 bytes read, 0 bits of entropy available)
[ 4.066845] random: udevadm: uninitialized urandom read (16 bytes read, 0 bits of entropy available)
[ 4.067830] usb 1-4: new high-speed USB device number 2 using ehci-pci
[ 4.068129] random: udevadm: uninitialized urandom read (16 bytes read, 0 bits of entropy available)
[ 4.068412] random: udevadm: uninitialized urandom read (16 bytes read, 0 bits of entropy available)
[ 4.068682] random: udevadm: uninitialized urandom read (16 bytes read, 0 bits of entropy available)
[ 4.068933] random: udevadm: uninitialized urandom read (16 bytes read, 0 bits of entropy available)
[ 4.069218] random: udevadm: uninitialized urandom read (16 bytes read, 0 bits of entropy available)
[ 4.069554] random: udevadm: uninitialized urandom read (16 bytes read, 0 bits of entropy available)
[ 4.201428] FUJITSU Extended Socket Network Device Driver - version 1.0 - Copyright (c) 2015 FUJITSU LIMITED
[ 4.287843] alx 0000:01:00.0 eth0: Qualcomm Atheros AR816x/AR817x Ethernet [00:26:6c:13:d9:08]
[ 4.309098] [drm] Initialized drm 1.1.0 20060810
[ 4.313430] ahci 0000:00:1f.2: version 3.0
[ 4.313865] ahci 0000:00:1f.2: SSS flag set, parallel bus scan disabled
[ 4.313933] ahci 0000:00:1f.2: AHCI 0001.0100 32 slots 4 ports 3 Gbps 0x3 impl SATA mode
[ 4.313946] ahci 0000:00:1f.2: flags: 64bit ncq ilck stag pm led clo pio slum part
[ 4.316902] scsi host0: ahci
[ 4.320135] scsi host1: ahci
[ 4.323247] scsi host2: ahci
[ 4.323903] scsi host3: ahci
[ 4.324219] ata1: SATA max UDMA/133 abar m1024@0x84104000 port 0x84104100 irq 26
[ 4.324232] ata2: SATA max UDMA/133 abar m1024@0x84104000 port 0x84104180 irq 26
[ 4.324239] ata3: DUMMY
[ 4.324245] ata4: DUMMY
[ 4.423504] alx 0000:01:00.0 enp1s0: renamed from eth0
[ 4.455206] pmd_set_huge: Cannot satisfy [mem 0x7f800000-0x7fa00000] with a huge-page mapping due to MTRR override.
[ 4.467230] usb 1-4: New USB device found, idVendor=0bda, idProduct=0138
[ 4.467239] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.467246] usb 1-4: Product: USB2.0-CRW
[ 4.467251] usb 1-4: Manufacturer: Generic
[ 4.467257] usb 1-4: SerialNumber: 20090516388200000
[ 4.469201] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 4.473305] acpi device:26: registered as cooling_device5
[ 4.473881] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input6
[ 4.474106] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 4.474112] [drm] No driver support for vblank timestamp query.
[ 4.639775] usb 1-6: new high-speed USB device number 3 using ehci-pci
[ 4.647791] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 4.648734] ata1.00: ATA-8: Hitachi HTS543232A7A384, ES2OA70K, max UDMA/133
[ 4.648743] ata1.00: 625142448 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[ 4.649778] ata1.00: configured for UDMA/133
[ 4.650210] scsi 0:0:0:0: Direct-Access ATA Hitachi HTS54323 A70K PQ: 0 ANSI: 5
[ 4.650967] sd 0:0:0:0: [sda] 625142448 512-byte logical blocks: (320 GB/298 GiB)
[ 4.651194] sd 0:0:0:0: [sda] Write Protect is off
[ 4.651205] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 4.651340] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 4.651350] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 4.695765] tsc: Refined TSC clocksource calibration: 1595.997 MHz
[ 4.695779] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x17015f78d9b, max_idle_ns: 440795253061 ns
[ 4.724105] sda: sda1 sda2 sda3 < sda5 sda6 >
[ 4.725559] sd 0:0:0:0: [sda] Attached SCSI disk
[ 4.847784] usb 1-6: New USB device found, idVendor=10f1, idProduct=1a34
[ 4.847795] usb 1-6: New USB device strings: Mfr=2, Product=1, SerialNumber=3
[ 4.847803] usb 1-6: Product: TOSHIBA Web Camera
[ 4.847810] usb 1-6: Manufacturer: Importek
[ 4.847817] usb 1-6: SerialNumber: MU462ASA
[ 4.880077] gma500 0000:00:02.0: trying to get vblank count for disabled pipe 1
[ 4.880094] gma500 0000:00:02.0: trying to get vblank count for disabled pipe 1
[ 4.888201] usbcore: registered new interface driver usb-storage
[ 4.904384] usbcore: registered new interface driver uas
[ 4.919376] ums-realtek 1-4:1.0: USB Mass Storage device detected
[ 4.934986] usb 1-4: USB disconnect, device number 2
[ 4.938944] scsi host4: usb-storage 1-4:1.0
[ 4.939346] usbcore: registered new interface driver ums-realtek
[ 4.971799] ata2: SATA link down (SStatus 0 SControl 300)
[ 4.978434] checking generic (7f800000 1e0000) vs hw (7f800000 7bf000)
[ 4.978442] fb: switching to psbdrmfb from VESA VGA
[ 4.978525] Console: switching to colour dummy device 80x25
[ 4.979006] fbcon: psbdrmfb (fb0) is primary device
[ 4.979212] Console: switching to colour frame buffer device 128x37
[ 4.979286] gma500 0000:00:02.0: fb0: psbdrmfb frame buffer device
[ 4.996024] [drm] Initialized gma500 1.0.0 20140314 for 0000:00:02.0 on minor 0
[ 5.246458] psmouse serio1: synaptics: queried max coordinates: x [..5612], y [..5080]
[ 5.358644] psmouse serio1: synaptics: Touchpad model: 1, fw: 7.2, id: 0x1c0b1, caps: 0xd04733/0xa40000/0xa0000/0x0, board id: 0, fw id: 549736
[ 5.429686] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input5
[ 5.696314] clocksource: Switched to clocksource tsc
[ 6.296155] EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: (null)
[ 6.734601] random: nonblocking pool is initialized
[ 7.638695] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 7.639215] systemd[1]: Detected architecture x86.
[ 7.647085] systemd[1]: Set hostname to <daniel-TOSHIBA-NB510>.
[ 9.629845] systemd[1]: Created slice User and Session Slice.
[ 9.630118] systemd[1]: Listening on udev Kernel Socket.
[ 9.630311] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 9.630421] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 9.630902] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 9.630969] systemd[1]: Reached target Encrypted Volumes.
[ 9.631017] systemd[1]: Reached target Remote File Systems (Pre).
[ 9.631171] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 9.631325] systemd[1]: Listening on udev Control Socket.
[ 9.631379] systemd[1]: Reached target User and Group Name Lookups.
[ 9.631633] systemd[1]: Listening on Journal Audit Socket.
[ 9.631688] systemd[1]: Reached target Remote File Systems.
[ 9.631922] systemd[1]: Listening on Journal Socket (/dev/log).
[ 9.632254] systemd[1]: Created slice System Slice.
[ 9.632353] systemd[1]: Reached target Slices.
[ 9.632492] systemd[1]: Listening on Syslog Socket.
[ 9.632660] systemd[1]: Listening on Journal Socket.
[ 9.680851] systemd[1]: Starting Uncomplicated firewall...
[ 9.684156] systemd[1]: Started Read required files in advance.
[ 9.686614] systemd[1]: Mounting Debug File System...
[ 9.688796] systemd[1]: Starting Set console keymap...
[ 9.691025] systemd[1]: Started Braille Device Support.
[ 9.693918] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 9.695995] systemd[1]: Mounting Huge Pages File System...
[ 9.698226] systemd[1]: Starting Nameserver information manager...
[ 9.700489] systemd[1]: Starting Journal Service...
[ 9.702460] systemd[1]: Mounting POSIX Message Queue File System...
[ 9.824328] systemd[1]: Starting Load Kernel Modules...
[ 10.054871] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 10.080445] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 10.532645] systemd[1]: Mounted Huge Pages File System.
[ 10.532789] systemd[1]: Mounted POSIX Message Queue File System.
[ 10.532869] systemd[1]: Mounted Debug File System.
[ 10.664418] systemd[1]: Started Nameserver information manager.
[ 10.810149] systemd[1]: Started Journal Service.
[ 11.078427] lp: driver loaded but no devices found
[ 11.131119] ppdev: user-space parallel port driver
[ 11.822908] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 11.948289] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 12.626372] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 15.315967] EXT4-fs (sda5): re-mounted. Opts: errors=remount-ro
[ 15.635230] systemd-journald[235]: Received request to flush runtime journal from PID 1
[ 16.695983] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 16.698015] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20150930/utaddress-254)
[ 16.698042] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000042F (\SWC1) (20150930/utaddress-254)
[ 16.698061] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 16.698074] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x000000000000053B (\GPIO) (20150930/utaddress-254)
[ 16.698092] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 16.698100] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000053B (\GPIO) (20150930/utaddress-254)
[ 16.698118] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 16.698125] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 16.737117] wmi: Mapper loaded
[ 18.943615] audit: type=1400 audit(1478513933.611:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=664 comm="apparmor_parser"
[ 18.943642] audit: type=1400 audit(1478513933.611:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=664 comm="apparmor_parser"
[ 19.081036] rtl8192ce: Using firmware rtlwifi/rtl8192cfwU_B.bin
[ 19.186119] ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
[ 19.186931] rtlwifi: rtlwifi: wireless switch is on
[ 19.282757] audit: type=1400 audit(1478513933.951:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cups-browsed" pid=665 comm="apparmor_parser"
[ 19.306763] audit: type=1400 audit(1478513933.975:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/sbin/dhclient" pid=662 comm="apparmor_parser"
[ 19.306810] audit: type=1400 audit(1478513933.975:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=662 comm="apparmor_parser"
[ 19.306839] audit: type=1400 audit(1478513933.975:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=662 comm="apparmor_parser"
[ 19.306867] audit: type=1400 audit(1478513933.975:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=662 comm="apparmor_parser"
[ 19.307334] cfg80211: World regulatory domain updated:
[ 19.307346] cfg80211: DFS Master region: unset
[ 19.307350] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 19.307358] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 19.307364] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 19.307369] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 19.307376] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 19.307383] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 19.307388] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 19.307394] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 19.307399] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 19.341561] audit: type=1400 audit(1478513934.011:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" pid=667 comm="apparmor_parser"
[ 19.341603] audit: type=1400 audit(1478513934.011:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cupsd" pid=667 comm="apparmor_parser"
[ 19.341631] audit: type=1400 audit(1478513934.011:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cupsd//third_party" pid=667 comm="apparmor_parser"
[ 19.551280] rtl8192ce 0000:02:00.0 wlp2s0: renamed from wlan0
[ 20.175647] media: Linux media interface: v0.10
[ 20.256179] Linux video capture interface: v2.00
[ 20.460398] snd_hda_codec_realtek hdaudioC0D2: autoconfig for ALC269VB: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 20.460409] snd_hda_codec_realtek hdaudioC0D2: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 20.460417] snd_hda_codec_realtek hdaudioC0D2: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 20.460422] snd_hda_codec_realtek hdaudioC0D2: mono: mono_out=0x0
[ 20.460427] snd_hda_codec_realtek hdaudioC0D2: inputs:
[ 20.460434] snd_hda_codec_realtek hdaudioC0D2: Mic=0x18
[ 20.460441] snd_hda_codec_realtek hdaudioC0D2: Internal Mic=0x12
[ 20.470417] input: HDA Intel HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[ 20.470780] input: HDA Intel Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 20.471122] input: HDA Intel Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 20.605734] Adding 2081788k swap on /dev/sda6. Priority:-1 extents:1 across:2081788k FS
[ 20.802055] uvcvideo: Found UVC 1.00 device TOSHIBA Web Camera (10f1:1a34)
[ 20.817106] input: TOSHIBA Web Camera as /devices/pci0000:00/0000:00:1d.7/usb1/1-6/1-6:1.0/input/input10
[ 20.817386] usbcore: registered new interface driver uvcvideo
[ 20.817394] USB Video Class driver (1.1.1)
[ 31.827551] IPv6: ADDRCONF(NETDEV_UP): enp1s0: link is not ready
[ 31.831832] IPv6: ADDRCONF(NETDEV_UP): enp1s0: link is not ready
[ 31.926364] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[ 32.301701] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[ 33.772528] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[ 40.514637] Non-volatile memory driver v1.3
[ 57.952129] wlp2s0: authenticate with 00:27:0d:b0:a7:20
[ 57.982221] wlp2s0: send auth to 00:27:0d:b0:a7:20 (try 1/3)
[ 57.984239] wlp2s0: authenticated
[ 57.987889] wlp2s0: associate with 00:27:0d:b0:a7:20 (try 1/3)
[ 57.993924] wlp2s0: RX AssocResp from 00:27:0d:b0:a7:20 (capab=0x421 status=0 aid=5)
[ 57.994473] wlp2s0: associated
[ 57.994652] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready
[ 58.007450] cfg80211: Regulatory domain changed to country: ES
[ 58.007461] cfg80211: DFS Master region: ETSI
[ 58.007467] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 58.007476] cfg80211: (2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 58.007485] cfg80211: (5150000 KHz - 5250000 KHz @ 80000 KHz, 200000 KHz AUTO), (N/A, 2301 mBm), (N/A)
[ 58.007495] cfg80211: (5250000 KHz - 5350000 KHz @ 80000 KHz, 200000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 58.007504] cfg80211: (5470000 KHz - 5725000 KHz @ 160000 KHz), (N/A, 2698 mBm), (0 s)
[ 58.007512] cfg80211: (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[ 58.022640] wlp2s0: Limiting TX power to 14 dBm as advertised by 00:27:0d:b0:a7:20
[ 71.384739] nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead.
[ 2305.268660] [UFW BLOCK] IN=wlp2s0 OUT= MAC=44:6d:57:42:83:99:00:d0:83:06:7c:c3:08:00 SRC=216.58.201.138 DST=10.210.225.81 LEN=107 TOS=0x00 PREC=0x00 TTL=64 ID=26199 PROTO=TCP SPT=443 DPT=46364 WINDOW=65535 RES=0x00 ACK PSH URGP=0
daniel@daniel-TOSHIBA-NB510:~$
Thanks a lot for your support.
Cheers,
Daniel
Hello Daniel,
Good job! Well off the bat, I can tell you that there is nothing wrong in this dmesg file. To make a long story short, the informations contained in this output covers all(as in: A-L-L) of the hardware being discovered and configured during boot.
That being said, it's always interesting to take a peep at this file whenever your system is having problems and that you are suspecting hardware (or system) corruption of some sort. If that's the case, then there would most probably be red error messages spammed all the way in that output.
Also, the longer your system is running the more lines there will be written in this file therefore comes one point when one can simply skip the first 20seconds of booting time
AKA
Therefore anything coming AFTER is generally a better indication of what's going on in your system at any given time.
In regards of dcfldd that's a software to be (mostly) used to erase hard drives. I would suggest going thru "man dcfldd" in other to learn more but the general way to invoke it is:
$ sudo dcfldd /dev/sda
Where /dev/sda is your HD. Again, this will DELETE ALL THE DATA from the drive without asking for a confirmation but on the bright side is when dcfldd is done one can recheck under dmesg to see if any errors poped-up while it was running.
Hope this helps,
