Just press Ctrl-L. It's a "form feed" character, the character that used to be used by line printers decades ago to force a new page to come out of the printer. Teletype terminals recognized it, too.
As far as I can tell, pressing the Ctrl + Shift+R keyboard shortcut / combination, in "MATE Terminal", does NOT clear the terminal screen, but enters the so-called "reverse-i-search" instead (which is a rather useful feature that allows you to search your command history).
My bad. I defer to your expertise. What probably happened is that long ago I may have double-clicked the line for the "Reset and Clear" shortcut in the Edit/Keyboard Shortcuts... dialog and changed the shortcut to something more memorable (at least for my feeble memory). Sorry for the confusion. I have deleted that reply so as not to lead others astray.
