I installed Mate minumum version and then installed Clementine. I note that version 1.4.0RC1 was the version available in the repositories. Running this fails with "QSQLITE driver not loaded" and many other errors resulting from this.
I then downloaded V1.31 Xenial from the Clementine website and this failed to install with missing dependency "libcdio13 >= 0.83"
Is anybody else experiencing this problem?
I am having the same error. Clementine crashes when starting.
What do you see when you run it from the terminal?
Press CTRL+ALT+T then type:
clementine
__logging_message__13:57:58.001 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__13:57:58.001 WARN unknown QSqlDatabase: available drivers:
__logging_message__13:57:58.016 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__13:57:58.016 WARN unknown QSqlDatabase: available drivers:
__logging_message__13:57:58.017 WARN unknown QSqlQuery::prepare: database not open
13:57:58.017 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
13:57:58.017 ERROR Database:596 faulty query: ""
13:57:58.017 ERROR Database:597 bound values: QMap()
__logging_message__13:57:58.137 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__13:57:58.137 WARN unknown QSqlDatabase: available drivers:
__logging_message__13:57:58.137 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94469113977776' is still in use, all queries will cease to work.
__logging_message__13:57:58.137 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94469113977776', old connection removed.
__logging_message__13:57:58.137 WARN unknown QSqlQuery::prepare: database not open
13:57:58.138 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
13:57:58.138 ERROR Database:596 faulty query: ""
13:57:58.138 ERROR Database:597 bound values: QMap()
__logging_message__13:57:58.138 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__13:57:58.138 WARN unknown QSqlDatabase: available drivers:
__logging_message__13:57:58.138 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94469113977776' is still in use, all queries will cease to work.
__logging_message__13:57:58.138 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94469113977776', old connection removed.
__logging_message__13:57:59.030 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__13:57:59.030 WARN unknown QSqlDatabase: available drivers:
__logging_message__13:57:59.030 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94469111106592' is still in use, all queries will cease to work.
__logging_message__13:57:59.030 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94469111106592', old connection removed.
__logging_message__13:57:59.062 WARN unknown QSqlQuery::prepare: database not open
13:57:59.062 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
13:57:59.062 ERROR Database:596 faulty query: ""
13:57:59.062 ERROR Database:597 bound values: QMap()
__logging_message__13:57:59.062 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__13:57:59.062 WARN unknown QSqlDatabase: available drivers:
__logging_message__13:57:59.062 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94469111106592' is still in use, all queries will cease to work.
__logging_message__13:57:59.062 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94469111106592', old connection removed.
__logging_message__13:57:59.063 WARN unknown QSqlQuery::prepare: database not open
13:57:59.063 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
13:57:59.063 ERROR Database:596 faulty query: ""
13:57:59.063 ERROR Database:597 bound values: QMap()
__logging_message__13:57:59.076 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__13:57:59.076 WARN unknown QSqlDatabase: available drivers:
__logging_message__13:57:59.076 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94469111106592' is still in use, all queries will cease to work.
__logging_message__13:57:59.076 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94469111106592', old connection removed.
__logging_message__13:57:59.076 WARN unknown QSqlQuery::prepare: database not open
13:57:59.076 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
13:57:59.076 ERROR Database:596 faulty query: ""
13:57:59.077 ERROR Database:597 bound values: QMap()
__logging_message__13:57:59.261 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__13:57:59.261 WARN unknown QSqlDatabase: available drivers:
__logging_message__13:57:59.261 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94469113977776' is still in use, all queries will cease to work.
__logging_message__13:57:59.261 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94469113977776', old connection removed.
__logging_message__13:57:59.261 WARN unknown QSqlQuery::prepare: database not open
13:57:59.261 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
13:57:59.261 ERROR Database:596 faulty query: ""
13:57:59.261 ERROR Database:597 bound values: QMap()
__logging_message__13:57:59.269 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__13:57:59.269 WARN unknown QSqlDatabase: available drivers:
__logging_message__13:57:59.269 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94469113977776' is still in use, all queries will cease to work.
__logging_message__13:57:59.269 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94469113977776', old connection removed.
__logging_message__13:57:59.269 WARN unknown QSqlQuery::prepare: database not open
13:57:59.269 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
13:57:59.269 ERROR Database:596 faulty query: ""
13:57:59.269 ERROR Database:597 bound values: QMap()
__logging_message__13:57:59.291 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__13:57:59.292 WARN unknown QSqlDatabase: available drivers:
__logging_message__13:57:59.292 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94469113977776' is still in use, all queries will cease to work.
__logging_message__13:57:59.292 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94469113977776', old connection removed.
__logging_message__13:57:59.292 WARN unknown QSqlQuery::prepare: database not open
13:57:59.292 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
13:57:59.292 ERROR Database:596 faulty query: ""
13:57:59.292 ERROR Database:597 bound values: QMap()
__logging_message__13:57:59.298 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__13:57:59.298 WARN unknown QSqlDatabase: available drivers:
__logging_message__13:57:59.298 WARN unknown QSqlQuery::prepare: database not open
13:57:59.299 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
13:57:59.299 ERROR Database:596 faulty query: ""
13:57:59.299 ERROR Database:597 bound values: QMap()
__logging_message__13:57:59.419 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__13:57:59.419 WARN unknown QSqlDatabase: available drivers:
__logging_message__13:57:59.419 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94469111106592' is still in use, all queries will cease to work.
__logging_message__13:57:59.419 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94469111106592', old connection removed.
__logging_message__13:57:59.420 WARN unknown QSqlQuery::exec: database not open
13:57:59.420 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
13:57:59.420 ERROR Database:596 faulty query: ""
13:57:59.420 ERROR Database:597 bound values: QMap()
__logging_message__13:57:59.426 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__13:57:59.426 WARN unknown QSqlDatabase: available drivers:
__logging_message__13:57:59.426 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94469113977776' is still in use, all queries will cease to work.
__logging_message__13:57:59.426 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94469113977776', old connection removed.
__logging_message__13:57:59.426 WARN unknown QSqlQuery::prepare: database not open
13:57:59.426 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
13:57:59.426 ERROR Database:596 faulty query: ""
13:57:59.426 ERROR Database:597 bound values: QMap()
__logging_message__13:57:59.432 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__13:57:59.432 WARN unknown QSqlDatabase: available drivers:
__logging_message__13:57:59.432 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94469113977776' is still in use, all queries will cease to work.
__logging_message__13:57:59.432 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94469113977776', old connection removed.
__logging_message__13:57:59.432 WARN unknown QSqlQuery::prepare: database not open
13:57:59.432 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
13:57:59.432 ERROR Database:596 faulty query: ""
13:57:59.432 ERROR Database:597 bound values: QMap()
__logging_message__13:57:59.439 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__13:57:59.439 WARN unknown QSqlDatabase: available drivers:
__logging_message__13:57:59.439 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94469113977776' is still in use, all queries will cease to work.
__logging_message__13:57:59.439 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94469113977776', old connection removed.
__logging_message__13:57:59.439 WARN unknown QSqlQuery::prepare: database not open
13:57:59.439 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
13:57:59.439 ERROR Database:596 faulty query: ""
13:57:59.439 ERROR Database:597 bound values: QMap()
__logging_message__13:57:59.444 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__13:57:59.444 WARN unknown QSqlDatabase: available drivers:
__logging_message__13:57:59.445 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94469113977776' is still in use, all queries will cease to work.
__logging_message__13:57:59.445 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94469113977776', old connection removed.
__logging_message__13:57:59.445 WARN unknown QSqlQuery::prepare: database not open
13:57:59.445 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
13:57:59.445 ERROR Database:596 faulty query: ""
13:57:59.445 ERROR Database:597 bound values: QMap()
__logging_message__13:57:59.446 WARN unknown libpng warning: iCCP: known incorrect sRGB profile
__logging_message__13:57:59.451 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__13:57:59.451 WARN unknown QSqlDatabase: available drivers:
__logging_message__13:57:59.451 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94469113977776' is still in use, all queries will cease to work.
__logging_message__13:57:59.451 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94469113977776', old connection removed.
__logging_message__13:57:59.451 WARN unknown QSqlQuery::prepare: database not open
13:57:59.451 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
13:57:59.452 ERROR Database:596 faulty query: ""
13:57:59.452 ERROR Database:597 bound values: QMap()
__logging_message__13:57:59.453 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__13:57:59.453 WARN unknown QSqlDatabase: available drivers:
__logging_message__13:57:59.453 WARN unknown QSqlQuery::prepare: database not open
13:57:59.453 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
13:57:59.453 ERROR Database:596 faulty query: ""
13:57:59.453 ERROR Database:597 bound values: QMap()
__logging_message__13:57:59.461 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__13:57:59.461 WARN unknown QSqlDatabase: available drivers:
__logging_message__13:57:59.461 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94469111106592' is still in use, all queries will cease to work.
__logging_message__13:57:59.461 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94469111106592', old connection removed.
__logging_message__13:57:59.462 WARN unknown QSqlQuery::prepare: database not open
13:57:59.462 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
13:57:59.462 ERROR Database:596 faulty query: ""
13:57:59.462 ERROR Database:597 bound values: QMap()
__logging_message__13:57:59.548 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__13:57:59.548 WARN unknown QSqlDatabase: available drivers:
__logging_message__13:57:59.548 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94469114208928' is still in use, all queries will cease to work.
__logging_message__13:57:59.548 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94469114208928', old connection removed.
__logging_message__13:57:59.548 WARN unknown QSqlQuery::prepare: database not open
13:57:59.548 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
13:57:59.548 ERROR Database:596 faulty query: ""
13:57:59.548 ERROR Database:597 bound values: QMap()
__logging_message__13:57:59.775 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__13:57:59.775 WARN unknown QSqlDatabase: available drivers:
__logging_message__13:57:59.775 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94469111106592' is still in use, all queries will cease to work.
__logging_message__13:57:59.775 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94469111106592', old connection removed.
__logging_message__13:57:59.776 WARN unknown QSqlQuery::prepare: database not open
13:57:59.776 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
13:57:59.776 ERROR Database:596 faulty query: ""
13:57:59.777 ERROR Database:597 bound values: QMap()
__logging_message__13:57:59.777 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__13:57:59.777 WARN unknown QSqlDatabase: available drivers:
__logging_message__13:57:59.777 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94469111106592' is still in use, all queries will cease to work.
__logging_message__13:57:59.777 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94469111106592', old connection removed.
__logging_message__13:57:59.778 WARN unknown QSqlQuery::prepare: database not open
13:57:59.778 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
13:57:59.778 ERROR Database:596 faulty query: ""
13:57:59.778 ERROR Database:597 bound values: QMap()
__logging_message__13:57:59.778 ERROR unknown Couldn't create playlist
Abortado (imagem do núcleo gravada)
Do you have the libqt5sql5 and libqt5sql5-sqlite packages installed?
To check, at the terminal again, run the following:
apt search libqt5sql5
You will see several lines. The two starting with the package names should end with something like [installed if they are installed.
If they are not installed, you can install them from the terminal with:
sudo apt install libqt5sql5 libqt5sql5-sqlite
If they are installed, something else is going on. I am not able to reproduce this with this application newly installed.
They are installed, let's wait a little more, it's just the beginning!
Thanks!!!
I had to install libqt5 etc as I had done a minimal install. Surprised it was omitted as it is only 279Kb. Here is a strange thing. I had installed the Cinnamon desktop for comparison and Clementine ran ok in Cinnamon. Back in Mate desktop it ran from the terminal but not from the menu. The monitor showed it loaded but sleeping with no gui. I reinstalled but it did not help. only minor messages when run from terminal as below. Congrats on the way 2 destops ran with no interference:
__logging_message__08:42:55.936 WARN unknown QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
__logging_message__08:42:57.644 WARN unknown libpng warning: iCCP: known incorrect sRGB profile
__logging_message__08:43:10.914 WARN unknown OpenType support missing for "Saab", script 13
__logging_message__08:43:11.533 WARN unknown libpng warning: iCCP: known incorrect sRGB profile
__logging_message__08:43:11.561 WARN unknown libpng warning: iCCP: known incorrect sRGB profile
__logging_message__08:43:11.632 WARN unknown libpng warning: iCCP: known incorrect sRGB profile
__logging_message__08:43:18.694 WARN unknown QObject::killTimer: Timers cannot be stopped from another thread
__logging_message__08:43:18.694 WARN unknown QObject::~QObject: Timers cannot be stopped from another thread
Could we get you to file a bug report on this please.
Thanks
The link takes me to a Panel discussion but I
believe you are referring to the Clementine issue. Apart from the
missing sqlite it seems to be a configuration issue which I cannot
reproduce. My Clementine.conf file shows startupbehaviour=3 and
showtrayicon=true which means the Main Window hidden with an icon
in the '` indicator-applet-complete'
applet. I removed this applet for various reasons so I ended up
with Clementine running in the background and no obvious method
to display it. Perhaps this applet should be made fixed as it
seems to be essential to other functions such as Network
display.
The reason I was able to run Clementine from a terminal was
because I happened to have a terminal open as 'root' and I used
this. The Clementine.conf in the root home folder used a
startupbehaviour=1 which always displays the Clementine as
remembered from last use.
I cannot remember changing this option at any time so I
completely uninstalled Clementine and manually deleted the conf
file. After a re-install Clementine started with the Main Screen
displayed OK.
Thanks for the update.
So it appears that if you install the missing libqt5sql5-sqlite dependency and then delete the ~./config/Clementine/Clementine.conf file than it will run successfully.
Can those who are having this issue try that and see if that work-around works for you? Also please quit Clementine and restart and see if that is working after that.
Thanks
Hi there!
It works here for me but the icon don't have the option to show clementine once I close the window application.
Thanks. We've gotten confirmation that this issue is occurring on some other distro's as well.
We are going to remove it from the Software Boutique for the time being.
What a pity!
Clementine is amazing, synchonize my music and likes via Last.fm.
It's time to look for a new music player!
Thanks for help all of us!
Don't give up all hope just yet.
Bug report created.
Please comment and click on this effects you.
