Command to directly launch Session menu
Hello,
I am configuring a new install of Ubuntu MATE 18.04 to look and function like Mac OS X.
The only thing I have left to do is the Apple menu in the upper left on the top panel.
I want to use a Custom Application Launcher that launches the Session menu. However, I don’t know and can’t find the command that directly launches the menu.
I tried using indicator-session but that just starts the applet that in turn launches the menu. I want the command that launches the Session menu directly.
I do have the Session menu indicator applet but it’s bundled with the other indicators on the right side of the panel.
Thanks for your help.
