So I changed the option “use marco theme” to be “TRUE” but the decorator stays with default cairo theme even after that . Yes I restarted my pc and compiz but still doesn’t work . Can somebody help ?
Hi @IvCHo,
I am sure you have already done so but run a full system update with the following terminal command in case of missing dependencies (Ctrl + Alt + t):
sudo apt-get update && sudo apt-get dist-upgrade -f
See also:
This is not compiz from the repo . Thia is the compiz-reloaded version . I previously unninstalled all compiz 0.9 and compiled the reloaded version so it won’t work
Then it may be a compatibility issue but I really don’t know, sorry!.
