Hello,
I'm looking for the "settings file" which set up the icons position ?
On my desktop I have icons / shortcuts / launchingapps icons / folder..., 2 above, 3below aligned,.... on every sessions / login I can find back the exact location for these icons (they are "memorised"). It should exist a file (settings) which set them up back at each login, I'm wondering where I can find it ?
I know caja manage the desktop,... but can't find anything relevant under .cache nor .conf...
I am under Mate 20.04.
Any idea ?
Thx
Hi ![]()
I don't know what you want to accomplish, but maybe this will be helpful :
You can read and write some attributes this way :
gio info /home/olek/Desktop/untitled\ folder/
unix::blocks: 8
owner::user: olek
owner::user-real: olek
owner::group: olek
metadata::caja-icon-position: 610,422
metadata::caja-icon-position-timestamp: 1610275908
metadata::icon-scale: 1
Good luck ![]()
