Hi... I am Ashik Shareef. I just started using Ubuntu Mate 18.04 LTS Bionic Beaver 32 bit a couple of months back. Recently I was offered by my friend his Canon Pixma E410 printer for my usage. I am new to Linux. So I don't know how to configure the printer for the first time. I could not find any driver for the printer online. Could somebody help me out with that?
click on add new printer......input your username and password
it should detect it as a local printer.....while I have a networked (wireless) printer
optional....click the box to share the printer.....recommend you do
click on make Canon and scroll down and select correct model as per
click on conitinue....setup your paper size and ink settings etc
do a test print etc
Thanks Bernie , stevecook172001 and aus9.. printer is detected automatically.. since its cartridge has to be replaced, I have ordered the same. Meanwhile, I want to use the scanner feature of the printer, as it is Print Scan and Copy device. How do I use that? Kindly throw some light.
