Hi guys!
I have a question about Conky. When I enable "own_window_argb_visual" the image becomes transparent and not just the background as it should be. Is there a way to fix it? I'm using Compiz and the latest Ubuntu Mate 18.04. I post the picture which shows the issue and my conkyrc. Thank you very much in advance!
alignment top_right
background yes
cpu_avg_samples 2
default_color 000000
default_outline_color 000000
default_shade_color 000000
double_buffer yes
draw_borders no
draw_graph_borders no
draw_outline no
draw_shades no
gap_x 20
gap_y 90
max_specials 1024
max_user_text 10000
maximum_width 100
minimum_size 300 400
net_avg_samples 2
no_buffers yes
override_utf8_locale yes
own_window yes
own_window_colour 000000
own_window_hints undecorated,below,sticky,skip_taskbar,skip_pager
own_window_transparent yes
own_window_type conky
own_window_argb_visual yes
own_window_argb_value 0
pad_percents 2
short_units yes
stippled_borders 3
text_buffer_size 8000
total_run_times 0
update_interval 3.0
uppercase no
use_spacer right
use_xft yes
xftalpha 1
TEXT
${offset 8}${voffset 16}${font OldSansBlack:size=22}${color #232323}${time %H}${offset 12}${time %M}${font}
${font pftempestafivecondensed:size=6}
${color white}Cpu: $cpu%
Core:${hwmon 0 temp 1}°C
Mem: $mem
Batt: ${battery_percent BAT0}%
HOME:${fs_used_perc /home}%
ROOT:${fs_used_perc /root}%
FREE:${fs_free_perc /home}%
Swap:${swapperc}%
CPU:${top cpu 1}%
${top name 1}
MEM:${top_mem mem 1}%
${top_mem name 1}
Signal:
${wireless_link_qual wlp3s0}%
Ul:${upspeed wlp3s0}
Dl:${downspeed wlp3s0}
${image ~/.conky/BackPRO.png 115x63 -p -1,204}
${image ~/.conky/BackDISK.png 115x63 -p -1,138}
${image ~/.conky/Back.png 115x63 -p -1,6}
${image ~/.conky/BackSYS.png 115x63 -p -1,72}
${image ~/.conky/BackNET.png 115x63 -p -1,270}
