Conky-manager help
Hi I have some issue with conky-manager after I have install it and applying a widget the weather info don’t shows and I can’t edit the file.
Just for record I’m new with ubuntu so my knowledge is low.
Hi
You need to edit the yahoo-weather number in the conky file. You can get the number in the url of the city you want:
https://weather.yahoo.com/united-kingdom/england/london-44418/
In example above is the number 44418 and you have to change it in your conky file (hidden file in your home folder, make visible with ctrl+H). u=c means temperature in Celsius.
