Constant restarts in ubuntu mate 22.04.1
It happened on fresh installs and than I went back to 20.04. When the upgrade became available I thought this would be stable. But still constant crashes / restarts. opening a link, opening a video, pic or just an other website... hoppa...
Whats going on : system:
leo@Leo:~$ inxi -Fxpmrz
System:
Kernel: 5.15.0-46-generic x86_64 bits: 64 compiler: gcc v: 11.2.0
Desktop: MATE 1.26.0 Distro: Ubuntu 22.04.1 LTS (Jammy Jellyfish)
Machine:
Type: Laptop System: Hewlett-Packard product: HP ProBook 6550b v: N/A
serial:
Mobo: Hewlett-Packard model: 146D v: KBC Version 73.11
serial: BIOS: Hewlett-Packard v: 68CDE Ver. F.03
date: 10/04/2010
Battery:
ID-1: BAT0 charge: 79.9 Wh (100.0%) condition: 79.9/71.3 Wh (112.1%)
volts: 12.6 min: 10.8 model: Hewlett-Packard Primary status: Full
Memory:
RAM: total: 7.56 GiB used: 1.35 GiB (17.8%)
RAM Report:
permissions: Unable to run dmidecode. Root privileges required.
CPU:
Info: dual core model: Intel Core i5 M 450 bits: 64 type: MT MCP
arch: Westmere rev: 5 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 1439 high: 1463 min/max: 1199/2400 boost: enabled
cores: 1: 1368 2: 1463 3: 1463 4: 1463 bogomips: 19151
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Graphics:
Device-1: Intel Core Processor Integrated Graphics vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0
Device-2: Primax Villem type: USB driver: uvcvideo bus-ID: 1-1.5:5
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: modesetting
unloaded: fbdev,vesa gpu: i915 resolution: 1366x768~60Hz
OpenGL: renderer: Mesa Intel HD Graphics (ILK) v: 2.1 Mesa 22.0.5
direct render: Yes
Audio:
Device-1: Intel 5 Series/3400 Series High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Sound Server-1: ALSA v: k5.15.0-46-generic running: yes
Sound Server-2: PulseAudio v: 15.99.1 running: yes
Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
Device-1: Intel 82577LC Gigabit Network vendor: Hewlett-Packard
driver: e1000e v: kernel port: 4000 bus-ID: 00:19.0
IF: enp0s25 state: down mac:
Device-2: Broadcom BCM4313 802.11bgn Wireless Network Adapter
vendor: Hewlett-Packard driver: wl v: kernel bus-ID: 44:00.0
IF: wlo1 state: up mac:
Bluetooth:
Device-1: HP Broadcom 2070 Bluetooth Combo type: USB driver: btusb v: 0.8
bus-ID: 1-1.1:3
Report: hciconfig ID: hci0 rfk-id: 4 state: up address:
bt-v: 1.2 lmp-v: 2.1
Drives:
Local Storage: total: 465.76 GiB used: 374.79 GiB (80.5%)
ID-1: /dev/sda vendor: Western Digital model: WDS500G2B0A-00SM50
Partition:
ID-1: / size: 456.88 GiB used: 374.78 GiB (82.0%) fs: ext4 dev: /dev/sda5
ID-2: /boot/efi size: 511 MiB used: 5.2 MiB (1.0%) fs: vfat
dev: /dev/sda1
Swap:
ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) file: /swapfile
Sensors:
System Temperatures: cpu: 32.0 C mobo: 0.0 C
Fan Speeds (RPM): N/A
Repos:
Packages: 2318
Processes: 218 Uptime: 6m Init: systemd runlevel: 5 Compilers: gcc: 11.2.0
I have deleted the packages because of link restrictions
