Hi Everyone, hope this help you to install an alternative software in order to use Scimitar RGB,
Also if you have some of this products of corsair:
Mice:
M65 RGB
Sabre RGB
Scimitar RGB
Keyboards:
K65 RGB
K70
K70 RGB
K95*
K95 RGB
StrafeStrafe RGB
This software will be usefull: ckb
to download go to: https://github.com/ccMSC/ckb/
and follow the instructions.
BEFORE INSTALLATION REMEMBER TO DOWNLOAD: Qt5, libudev, zlib, gcc, g++, and glibc.
by typing:
sudo apt-get install build-essential libudev-dev qt5-default zlib1g-dev libappindicator-dev
and
sudo apt-get update
then, as it says in the webpage:
You can download ckb using the “Download zip” option on the right .
Extract the file (probably it will be: ckb-master.zip) and open the ckb-master directory.
open the terminal in that directory and write:
./quickinstall
the application will be open after the installation.
if you want to open the application later use this command in terminal: ckb
