Could not load GPU driver
Hello. I'm new to Linux. I can't get a laptop with a nvidia card.
System info
Отчет о подробностях системы
Подробности отчета
  • Дата создания: 2024-04-20 23:14:49
Hardware Information:
  • Модель оборудования: ARDOR GAMING NP5x_60_7x_RNx1
  • Память: 16,0 ГиБ
  • Процессор: 12th Gen Intel® Core™ i5-12450H × 12
  • Графика: Intel® Graphics (ADL GT2)
  • Ёмкость диска: 512,1 ГБ
Software Information:
  • Версия прошивки: 1.07.05TDC
  • Название ОС: Ubuntu 23.10
  • Сборка ОС: (null)
  • Тип ОС: 64-бит
  • Версия GNOME: 45.2
  • Оконный интерфейс: X11
  • Версия ядра: Linux 6.5.0-28-generic
Problem: Графика: Intel® Graphics (ADL GT2)
I need the system to use GeForce RTX 3050.
sudo lspci -vnn | grep -i VGA -A 25
00:02.0 VGA compatible controller [0300]: Intel Corporation Alder Lake-P GT1 [UHD Graphics] [8086:46a3] (rev 0c) (prog-if 00 [VGA controller])
Subsystem: CLEVO/KAPOK Computer Alder Lake-P GT1 [UHD Graphics] [1558:a552]
Flags: bus master, fast devsel, latency 0, IRQ 139
Memory at 6202000000 (64-bit, non-prefetchable) [size=16M]
Memory at 4000000000 (64-bit, prefetchable) [size=256M]
I/O ports at 5000 [size=64]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Capabilities: [40] Vendor Specific Information: Len=0c <?>
Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [ac] MSI: Enable+ Count=1/1 Maskable+ 64bit-
Capabilities: [d0] Power Management version 2
Capabilities: [100] Process Address Space ID (PASID)
Capabilities: [200] Address Translation Service (ATS)
Capabilities: [300] Page Request Interface (PRI)
Capabilities: [320] Single Root I/O Virtualization (SR-IOV)
Kernel driver in use: i915
Kernel modules: i915
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GN20-P0-R-K2 [GeForce RTX 3050 6GB Laptop GPU] [10de:25ac] (rev a1) (prog-if 00 [VGA controller])
Subsystem: CLEVO/KAPOK Computer GN20-P0-R-K2 [GeForce RTX 3050 6GB Laptop GPU] [1558:a552]
Physical Slot: 1
Flags: fast devsel, IRQ 255
Memory at 75000000 (32-bit, non-prefetchable) [disabled] [size=16M]
Memory at 6000000000 (64-bit, prefetchable) [disabled] [size=8G]
Memory at 6200000000 (64-bit, prefetchable) [disabled] [size=32M]
I/O ports at 4000 [disabled] [size=128]
Expansion ROM at 76080000 [disabled] [size=512K]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Legacy Endpoint, MSI 00
Capabilities: [b4] Vendor Specific Information: Len=14 <?>
Capabilities: [100] Virtual Channel
Capabilities: [250] Latency Tolerance Reporting
Capabilities: [258] L1 PM Substates
Capabilities: [128] Power Budgeting <?>
Capabilities: [420] Advanced Error Reporting
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900] Secondary PCI Express
Capabilities: [bb0] Physical Resizable BAR
Capabilities: [c1c] Physical Layer 16.0 GT/s <?>
Capabilities: [d00] Lane Margining at the Receiver <?>
Capabilities: [e00] Data Link Feature <?>
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
dpkg -l | grep -i nvidia
ii bbswitch-dkms 0.8-15ubuntu1 amd64 Interface for toggling the power on NVIDIA Optimus video cards (dkms)
ii bumblebee 3.2.1-29ubuntu1 amd64 NVIDIA Optimus support for Linux
ii bumblebee-nvidia 3.2.1-29ubuntu1 amd64 NVIDIA Optimus support using the proprietary NVIDIA driver
ii libnvidia-cfg1-535-server:amd64 535.161.08-0ubuntu2.23.10.1 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-535-server 535.161.08-0ubuntu2.23.10.1 all Shared files used by the NVIDIA libraries
ii libnvidia-compute-535-server:amd64 535.161.08-0ubuntu2.23.10.1 amd64 NVIDIA libcompute package
ii libnvidia-compute-535-server:i386 535.161.08-0ubuntu2.23.10.1 i386 NVIDIA libcompute package
ii libnvidia-decode-535-server:amd64 535.161.08-0ubuntu2.23.10.1 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-decode-535-server:i386 535.161.08-0ubuntu2.23.10.1 i386 NVIDIA Video Decoding runtime libraries
ii libnvidia-encode-535-server:amd64 535.161.08-0ubuntu2.23.10.1 amd64 NVENC Video Encoding runtime library
ii libnvidia-encode-535-server:i386 535.161.08-0ubuntu2.23.10.1 i386 NVENC Video Encoding runtime library
ii libnvidia-extra-535-server:amd64 535.161.08-0ubuntu2.23.10.1 amd64 Extra libraries for the NVIDIA Server Driver
ii libnvidia-fbc1-535-server:amd64 535.161.08-0ubuntu2.23.10.1 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-fbc1-535-server:i386 535.161.08-0ubuntu2.23.10.1 i386 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-535-server:amd64 535.161.08-0ubuntu2.23.10.1 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-gl-535-server:i386 535.161.08-0ubuntu2.23.10.1 i386 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii nvidia-compute-utils-535-server 535.161.08-0ubuntu2.23.10.1 amd64 NVIDIA compute utilities
ii nvidia-dkms-535-server 535.161.08-0ubuntu2.23.10.1 amd64 NVIDIA DKMS package
ii nvidia-driver-535-server 535.161.08-0ubuntu2.23.10.1 amd64 NVIDIA Server Driver metapackage
ii nvidia-firmware-535-server-535.161.08 535.161.08-0ubuntu2.23.10.1 amd64 Firmware files used by the kernel module
ii nvidia-kernel-common-535-server 535.161.08-0ubuntu2.23.10.1 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-535-server 535.161.08-0ubuntu2.23.10.1 amd64 NVIDIA kernel source package
ii nvidia-primus-vk-common 1.6.3-1 amd64 thin wrapper for the NVIDIA binary Vulkan ICD (common files)
ii nvidia-primus-vk-wrapper:amd64 1.6.3-1 amd64 thin wrapper for using the NVIDIA binary Vulkan ICD with bumblebee
ii nvidia-settings 550.54.15-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-535-server 535.161.08-0ubuntu2.23.10.1 amd64 NVIDIA Server Driver support binaries
ii primus 0~20150328-15 amd64 client-side GPU offloading for NVIDIA Optimus
ii screen-resolution-extra 0.18.3 all Extension for the nvidia-settings control panel
ii xserver-xorg-video-nvidia-535-server 535.161.08-0ubuntu2.23.10.1 amd64 NVIDIA binary Xorg driver
nvidia-xconfig
Using X configuration file: "/etc/X11/xorg.conf".
ERROR: Unable to find any GPUs in the system.
Backed up file '/etc/X11/xorg.conf' as '/etc/X11/xorg.conf.backup'
New X configuration file written to '/etc/X11/xorg.conf'
I'm already tired of installing different versions of the driver. Please help me.
I also try bumblebee:
optirun steam
[ 1411.557862] [ERROR]Cannot access secondary GPU - error: Could not load GPU driver
[ 1411.557875] [ERROR]Aborting because fallback start is disabled.
Welcome @lihwar1 to the community!
you may have to enable the RTX from the bios menu of the laptop, it seems it is picking the onboard UHD gpu included in your cpu).
I have a stripped-down BIOS, so I can't really change anything there. And it seems that this is not the case, because some time ago everything worked.
So. I have some progress today.
I have updated the drivers to version 550. It wasn't that easy. It turns out that there were still dkms files from an even newer version that had to be deleted manually.
Plus, ubuntu-drivers did not install this version due to some dependency problems, but it was possible to install it through apt.
I also used the sudo prime-select nvidia.
Now the drivers are working. nvidia-xconfig no longer complains about not being able to find the GPU.
And nvidia-smi started working.
nvidia-smi
Sun Apr 21 13:51:43 2024
| NVIDIA-SMI 550.54.15 Driver Version: 550.54.15 CUDA Version: 12.4 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap | Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 3050 ... Off | 00000000:01:00.0 Off | N/A |
| N/A 39C P0 N/A / 70W | 1MiB / 6144MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| No running processes found |
But all this requires a reboot, and after it I just get a black screen. Nothing happens.
Sometimes, I manage to open the console using Meta + right arrow, and there I check again that the drivers are working.
I tried to do:
X :0 & export DISPLAY=:0
but in this case the console disappears. I can't open a new console the same way. And I can’t interact in any way.
A couple of times, while continuing to try to open the console via Meta + arrow, an interface with a login window suddenly appeared, but after entering the password, nothing happens and I am prompted to select a user again. At the same time, this situation is extremely unstable. I can't show this every time.
Same thing with prime-select on-demand.
Therefore, you have to do prime-select intel in order to be able to go into the browser and continue looking for a solution.
Xorg.0.log
[  1450.850]
X.Org X Server 1.21.1.7
X Protocol Version 11, Revision 0
[  1450.850] Current Operating System: Linux ldc-ardor-neo 6.5.0-28-generic #29-Ubuntu SMP PREEMPT_DYNAMIC Thu Mar 28 23:46:48 UTC 2024 x86_64
[  1450.850] Kernel command line: BOOT_IMAGE=/vmlinuz-6.5.0-28-generic root=/dev/mapper/ubuntu--vg-ubuntu--lv ro single recovery nomodeset dis_ucode_ldr
[  1450.850] xorg-server 2:21.1.7-3ubuntu2.9 (For technical support please see http://www.ubuntu.com/support)
[  1450.850] Current version of pixman: 0.42.2
[  1450.850] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[  1450.850] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[  1450.850] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Apr 21 13:52:07 2024
[  1450.850] (==) Using config file: "/etc/X11/xorg.conf"
[  1450.850] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[  1450.850] (==) ServerLayout "layout"
[  1450.850] (**) |-->Screen "Screen0" (0)
[  1450.850] (**) |   |-->Monitor "Monitor0"
[  1450.850] (**) |   |-->Device "Device0"
[  1450.850] (==) Automatically adding devices
[  1450.850] (==) Automatically enabling devices
[  1450.850] (==) Automatically adding GPU devices
[  1450.850] (==) Automatically binding GPU devices
[  1450.850] (==) Max clients allowed: 256, resource mask: 0x1fffff
[  1450.850] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[  1450.850] 	Entry deleted from font path.
[  1450.850] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[  1450.850] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[  1450.850] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[  1450.850] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[  1450.850] (==) FontPath set to:
	/usr/share/fonts/X11/misc,
	/usr/share/fonts/X11/Type1,
	built-ins
[  1450.850] (==) ModulePath set to "/usr/lib/xorg/modules"
[  1450.850] (II) The server relies on udev to provide the list of input devices.
	If no devices become available, reconfigure udev or disable AutoAddDevices.
[  1450.850] (II) Loader magic: 0x5742449db020
[  1450.850] (II) Module ABI versions:
[  1450.850] 	X.Org ANSI C Emulation: 0.4
[  1450.850] 	X.Org Video Driver: 25.2
[  1450.850] 	X.Org XInput driver : 24.4
[  1450.850] 	X.Org Server Extension : 10.0
[  1450.854] (--) using VT number 1
[  1450.854] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[  1450.854] (II) xfree86: Adding drm device (/dev/dri/card0)
[  1450.854] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card0
[  1450.875] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/x86_64-linux-gnu/nvidia/xorg,/usr/lib/xorg/modules"
[  1450.875] (--) PCI:*(0@0:2:0) 8086:46a3:1558:a552 rev 12, Mem @ 0x6202000000/16777216, 0x4000000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x????????/131072
[  1450.875] (--) PCI: (1@0:0:0) 10de:25ac:1558:a552 rev 161, Mem @ 0x75000000/16777216, 0x6000000000/8589934592, 0x6200000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x????????/524288
[  1450.875] (II) LoadModule: "glx"
[  1450.876] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[  1450.876] (II) Module glx: vendor="X.Org Foundation"
[  1450.876] 	compiled for 1.21.1.7, module version = 1.0.0
[  1450.876] 	ABI class: X.Org Server Extension, version 10.0
[  1450.876] (II) LoadModule: "nvidia"
[  1450.876] (II) Loading /usr/lib/x86_64-linux-gnu/nvidia/xorg/nvidia_drv.so
[  1450.876] (II) Module nvidia: vendor="NVIDIA Corporation"
[  1450.876] 	compiled for 1.6.99.901, module version = 1.0.0
[  1450.876] 	Module class: X.Org Video Driver
[  1450.876] (II) NVIDIA dlloader X Driver  550.54.15  Tue Mar  5 22:03:48 UTC 2024
[  1450.876] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[  1450.878] (II) Loading sub module "fb"
[  1450.878] (II) LoadModule: "fb"
[  1450.878] (II) Module "fb" already built-in
[  1450.878] (II) Loading sub module "wfb"
[  1450.878] (II) LoadModule: "wfb"
[  1450.878] (II) Loading /usr/lib/xorg/modules/libwfb.so
[  1450.878] (II) Module wfb: vendor="X.Org Foundation"
[  1450.878] 	compiled for 1.21.1.7, module version = 1.0.0
[  1450.878] 	ABI class: X.Org ANSI C Emulation, version 0.4
[  1450.878] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[  1450.878] (==) NVIDIA(0): RGB weight 888
[  1450.878] (==) NVIDIA(0): Default visual is TrueColor
[  1450.878] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[  1450.880] (**) Option "AllowNVIDIAGpuScreens"
[  1450.880] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[  1450.880] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[  1450.880] (**) NVIDIA(0): Enabling 2D acceleration
[  1450.880] (II) Loading sub module "glxserver_nvidia"
[  1450.880] (II) LoadModule: "glxserver_nvidia"
[  1450.880] (II) Loading /usr/lib/x86_64-linux-gnu/nvidia/xorg/libglxserver_nvidia.so
[  1450.911] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[  1450.911] 	compiled for 1.6.99.901, module version = 1.0.0
[  1450.911] 	Module class: X.Org Server Extension
[  1450.911] (II) NVIDIA GLX Module  550.54.15  Tue Mar  5 22:04:43 UTC 2024
[  1450.912] (II) NVIDIA: The X server supports PRIME Render Offload.
[  1450.913] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[  1450.913] (--) NVIDIA(0):     DFP-0
[  1450.913] (--) NVIDIA(0):     DFP-1
[  1450.913] (II) NVIDIA(0): NVIDIA GPU NVIDIA GeForce RTX 3050 6GB Laptop GPU (GA107-A) at
[  1450.913] (II) NVIDIA(0):     PCI:1:0:0 (GPU-0)
[  1450.913] (--) NVIDIA(0): Memory: 6291456 kBytes
[  1450.913] (--) NVIDIA(0): VideoBIOS: 94.07.87.00.de
[  1450.913] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[  1450.913] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  1450.913] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[  1450.913] (--) NVIDIA(GPU-0): DFP-0: 2670.0 MHz maximum pixel clock
[  1450.914] (--) NVIDIA(GPU-0): DFP-1: disconnected
[  1450.914] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[  1450.914] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[  1450.914] (==) NVIDIA(0):
[  1450.914] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[  1450.914] (==) NVIDIA(0):     will be used as the requested mode.
[  1450.914] (--) NVIDIA(0): No enabled display devices found; starting anyway because
[  1450.914] (--) NVIDIA(0):     AllowEmptyInitialConfiguration is enabled
[  1450.918] (II) NVIDIA(0): Validated MetaModes:
[  1450.918] (II) NVIDIA(0):     "NULL"
[  1450.918] (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
[  1450.918] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[  1450.918] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[  1450.918] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[  1450.918] (II) NVIDIA:     access.
[  1450.926] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[  1450.926] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[  1450.926] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[  1450.926] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[  1450.926] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[  1450.926] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[  1450.926] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[  1450.926] (II) NVIDIA(0):     Config Options in the README.
[  1450.939] (II) NVIDIA(0): Setting mode "NULL"
[  1450.950] (==) NVIDIA(0): Disabling shared memory pixmaps
[  1450.950] (==) NVIDIA(0): Backing store enabled
[  1450.950] (==) NVIDIA(0): Silken mouse enabled
[  1450.950] (**) NVIDIA(0): DPMS enabled
[  1450.950] (II) Loading sub module "dri2"
[  1450.950] (II) LoadModule: "dri2"
[  1450.950] (II) Module "dri2" already built-in
[  1450.950] (II) NVIDIA(0): [DRI2] Setup complete
[  1450.950] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[  1450.950] (II) Initializing extension Generic Event Extension
[  1450.950] (II) Initializing extension SHAPE
[  1450.950] (II) Initializing extension MIT-SHM
[  1450.950] (II) Initializing extension XInputExtension
[  1450.951] (II) Initializing extension XTEST
[  1450.951] (II) Initializing extension BIG-REQUESTS
[  1450.951] (II) Initializing extension SYNC
[  1450.951] (II) Initializing extension XKEYBOARD
[  1450.951] (II) Initializing extension XC-MISC
[  1450.951] (II) Initializing extension SECURITY
[  1450.951] (II) Initializing extension XFIXES
[  1450.951] (II) Initializing extension RENDER
[  1450.951] (II) Initializing extension RANDR
[  1450.951] (II) Initializing extension COMPOSITE
[  1450.951] (II) Initializing extension DAMAGE
[  1450.951] (II) Initializing extension MIT-SCREEN-SAVER
[  1450.951] (II) Initializing extension DOUBLE-BUFFER
[  1450.951] (II) Initializing extension RECORD
[  1450.951] (II) Initializing extension DPMS
[  1450.951] (II) Initializing extension Present
[  1450.951] (II) Initializing extension DRI3
[  1450.951] (II) Initializing extension X-Resource
[  1450.951] (II) Initializing extension XVideo
[  1450.951] (II) Initializing extension XVideo-MotionCompensation
[  1450.951] (II) Initializing extension SELinux
[  1450.951] (II) SELinux: Disabled on system
[  1450.951] (II) Initializing extension GLX
[  1450.952] (II) Initializing extension GLX
[  1450.952] (II) Indirect GLX disabled.
[  1450.952] (II) GLX: Another vendor is already registered for screen 0
[  1450.952] (II) Initializing extension XFree86-VidModeExtension
[  1450.952] (II) Initializing extension XFree86-DGA
[  1450.952] (II) Initializing extension XFree86-DRI
[  1450.952] (II) Initializing extension DRI2
[  1450.952] (II) Initializing extension NV-GLX
[  1450.952] (II) Initializing extension NV-CONTROL
[  1450.983] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[  1450.983] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[  1450.983] (II) LoadModule: "libinput"
[  1450.983] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[  1450.984] (II) Module libinput: vendor="X.Org Foundation"
[  1450.984] 	compiled for 1.21.1.7, module version = 1.3.0
[  1450.984] 	Module class: X.Org XInput Driver
[  1450.984] 	ABI class: X.Org XInput driver, version 24.4
[  1450.984] (II) Using input driver 'libinput' for 'Power Button'
[  1450.984] (**) Power Button: always reports core events
[  1450.984] (**) Option "Device" "/dev/input/event3"
[  1450.985] (II) event3  - Power Button: is tagged by udev as: Keyboard
[  1450.985] (II) event3  - Power Button: device is a keyboard
[  1450.985] (II) event3  - Power Button: device removed
[  1451.016] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[  1451.016] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[  1451.016] (**) Option "xkb_model" "pc105"
[  1451.016] (**) Option "xkb_layout" "us,ru"
[  1451.016] (**) Option "xkb_variant" ","
[  1451.026] (II) event3  - Power Button: is tagged by udev as: Keyboard
[  1451.026] (II) event3  - Power Button: device is a keyboard
[  1451.027] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[  1451.027] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[  1451.027] (II) Using input driver 'libinput' for 'Power Button'
[  1451.027] (**) Power Button: always reports core events
[  1451.027] (**) Option "Device" "/dev/input/event0"
[  1451.027] (II) event0  - Power Button: is tagged by udev as: Keyboard
[  1451.028] (II) event0  - Power Button: device is a keyboard
[  1451.028] (II) event0  - Power Button: device removed
[  1451.084] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[  1451.084] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[  1451.084] (**) Option "xkb_model" "pc105"
[  1451.084] (**) Option "xkb_layout" "us,ru"
[  1451.084] (**) Option "xkb_variant" ","
[  1451.084] (II) event0  - Power Button: is tagged by udev as: Keyboard
[  1451.084] (II) event0  - Power Button: device is a keyboard
[  1451.085] (II) config/udev: Adding input device Lid Switch (/dev/input/event2)
[  1451.085] (II) No input driver specified, ignoring this device.
[  1451.085] (II) This device may have been added with another device file.
[  1451.085] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[  1451.085] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[  1451.085] (II) Using input driver 'libinput' for 'Sleep Button'
[  1451.085] (**) Sleep Button: always reports core events
[  1451.085] (**) Option "Device" "/dev/input/event1"
[  1451.085] (II) event1  - Sleep Button: is tagged by udev as: Keyboard
[  1451.085] (II) event1  - Sleep Button: device is a keyboard
[  1451.085] (II) event1  - Sleep Button: device removed
[  1451.128] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
[  1451.128] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 8)
[  1451.128] (**) Option "xkb_model" "pc105"
[  1451.128] (**) Option "xkb_layout" "us,ru"
[  1451.128] (**) Option "xkb_variant" ","
[  1451.128] (II) event1  - Sleep Button: is tagged by udev as: Keyboard
[  1451.128] (II) event1  - Sleep Button: device is a keyboard
[  1451.129] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event10)
[  1451.129] (II) No input driver specified, ignoring this device.
[  1451.129] (II) This device may have been added with another device file.
[  1451.129] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event11)
[  1451.129] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event12)
[  1451.129] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event13)
[  1451.129] (II) config/udev: Adding input device HP HP Pavilion Gaming Mouse 200 (/dev/input/event7)
[  1451.129] (**) HP HP Pavilion Gaming Mouse 200: Applying InputClass "libinput pointer catchall"
[  1451.129] (II) Using input driver 'libinput' for 'HP HP Pavilion Gaming Mouse 200'
[  1451.129] (**) HP HP Pavilion Gaming Mouse 200: always reports core events
[  1451.129] (**) Option "Device" "/dev/input/event7"
[  1451.188] (II) event7  - HP HP Pavilion Gaming Mouse 200: is tagged by udev as: Mouse
[  1451.189] (II) event7  - HP HP Pavilion Gaming Mouse 200: device is a pointer
[  1451.189] (II) event7  - HP HP Pavilion Gaming Mouse 200: device removed
[  1451.268] (II) libinput: HP HP Pavilion Gaming Mouse 200: Step value 0 was provided, libinput Fallback acceleration function is used.
[  1451.268] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-5/3-5:1.0/0003:03F0:2C41.0002/input/input10/event7"
[  1451.268] (II) XINPUT: Adding extended input device "HP HP Pavilion Gaming Mouse 200" (type: MOUSE, id 9)
[  1451.268] (**) Option "AccelerationScheme" "none"
[  1451.268] (**) HP HP Pavilion Gaming Mouse 200: (accel) selected scheme none/0
[  1451.268] (**) HP HP Pavilion Gaming Mouse 200: (accel) acceleration factor: 2.000
[  1451.268] (**) HP HP Pavilion Gaming Mouse 200: (accel) acceleration threshold: 4
[  1451.328] (II) event7  - HP HP Pavilion Gaming Mouse 200: is tagged by udev as: Mouse
[  1451.328] (II) event7  - HP HP Pavilion Gaming Mouse 200: device is a pointer
[  1451.329] (II) config/udev: Adding input device HP HP Pavilion Gaming Mouse 200 (/dev/input/mouse2)
[  1451.329] (II) No input driver specified, ignoring this device.
[  1451.329] (II) This device may have been added with another device file.
[  1451.329] (II) config/udev: Adding input device FTCS1000:01 2808:0101 Mouse (/dev/input/event6)
[  1451.329] (**) FTCS1000:01 2808:0101 Mouse: Applying InputClass "libinput pointer catchall"
[  1451.329] (II) Using input driver 'libinput' for 'FTCS1000:01 2808:0101 Mouse'
[  1451.329] (**) FTCS1000:01 2808:0101 Mouse: always reports core events
[  1451.329] (**) Option "Device" "/dev/input/event6"
[  1451.329] (II) event6  - FTCS1000:01 2808:0101 Mouse: is tagged by udev as: Mouse Pointingstick
[  1451.329] (II) event6  - FTCS1000:01 2808:0101 Mouse: device is a pointer
[  1451.330] (II) event6  - FTCS1000:01 2808:0101 Mouse: device removed
[  1451.360] (II) libinput: FTCS1000:01 2808:0101 Mouse: Step value 0 was provided, libinput Fallback acceleration function is used.
[  1451.360] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-FTCS1000:01/0018:2808:0101.0001/input/input12/event6"
[  1451.360] (II) XINPUT: Adding extended input device "FTCS1000:01 2808:0101 Mouse" (type: MOUSE, id 10)
[  1451.360] (**) Option "AccelerationScheme" "none"
[  1451.360] (**) FTCS1000:01 2808:0101 Mouse: (accel) selected scheme none/0
[  1451.360] (**) FTCS1000:01 2808:0101 Mouse: (accel) acceleration factor: 2.000
[  1451.360] (**) FTCS1000:01 2808:0101 Mouse: (accel) acceleration threshold: 4
[  1451.360] (II) event6  - FTCS1000:01 2808:0101 Mouse: is tagged by udev as: Mouse Pointingstick
[  1451.361] (II) event6  - FTCS1000:01 2808:0101 Mouse: device is a pointer
[  1451.361] (II) config/udev: Adding input device FTCS1000:01 2808:0101 Mouse (/dev/input/mouse0)
[  1451.361] (II) No input driver specified, ignoring this device.
[  1451.361] (II) This device may have been added with another device file.
[  1451.361] (II) config/udev: Adding input device FTCS1000:01 2808:0101 Touchpad (/dev/input/event9)
[  1451.361] (**) FTCS1000:01 2808:0101 Touchpad: Applying InputClass "libinput touchpad catchall"
[  1451.361] (II) Using input driver 'libinput' for 'FTCS1000:01 2808:0101 Touchpad'
[  1451.361] (**) FTCS1000:01 2808:0101 Touchpad: always reports core events
[  1451.361] (**) Option "Device" "/dev/input/event9"
[  1451.362] (II) event9  - FTCS1000:01 2808:0101 Touchpad: is tagged by udev as: Touchpad
[  1451.362] (II) event9  - FTCS1000:01 2808:0101 Touchpad: device is a touchpad
[  1451.362] (II) event9  - FTCS1000:01 2808:0101 Touchpad: device removed
[  1451.392] (II) libinput: FTCS1000:01 2808:0101 Touchpad: Step value 0 was provided, libinput Fallback acceleration function is used.
[  1451.392] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-FTCS1000:01/0018:2808:0101.0001/input/input13/event9"
[  1451.392] (II) XINPUT: Adding extended input device "FTCS1000:01 2808:0101 Touchpad" (type: TOUCHPAD, id 11)
[  1451.393] (**) Option "AccelerationScheme" "none"
[  1451.393] (**) FTCS1000:01 2808:0101 Touchpad: (accel) selected scheme none/0
[  1451.393] (**) FTCS1000:01 2808:0101 Touchpad: (accel) acceleration factor: 2.000
[  1451.393] (**) FTCS1000:01 2808:0101 Touchpad: (accel) acceleration threshold: 4
[  1451.393] (II) event9  - FTCS1000:01 2808:0101 Touchpad: is tagged by udev as: Touchpad
[  1451.394] (II) event9  - FTCS1000:01 2808:0101 Touchpad: device is a touchpad
[  1451.394] (II) config/udev: Adding input device FTCS1000:01 2808:0101 Touchpad (/dev/input/mouse1)
[  1451.394] (II) No input driver specified, ignoring this device.
[  1451.394] (II) This device may have been added with another device file.
[  1451.394] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event14)
[  1451.394] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event15)
[  1451.395] (II) config/udev: Adding input device Intel HID events (/dev/input/event5)
[  1451.395] (**) Intel HID events: Applying InputClass "libinput keyboard catchall"
[  1451.395] (II) Using input driver 'libinput' for 'Intel HID events'
[  1451.395] (**) Intel HID events: always reports core events
[  1451.395] (**) Option "Device" "/dev/input/event5"
[  1451.395] (II) event5  - Intel HID events: is tagged by udev as: Keyboard
[  1451.395] (II) event5  - Intel HID events: device is a keyboard
[  1451.395] (II) event5  - Intel HID events: device removed
[  1451.416] (**) Option "config_info" "udev:/sys/devices/platform/INTC1051:00/input/input11/event5"
[  1451.416] (II) XINPUT: Adding extended input device "Intel HID events" (type: KEYBOARD, id 12)
[  1451.416] (**) Option "xkb_model" "pc105"
[  1451.416] (**) Option "xkb_layout" "us,ru"
[  1451.416] (**) Option "xkb_variant" ","
[  1451.416] (II) event5  - Intel HID events: is tagged by udev as: Keyboard
[  1451.416] (II) event5  - Intel HID events: device is a keyboard
[  1451.417] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[  1451.417] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[  1451.417] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[  1451.417] (**) AT Translated Set 2 keyboard: always reports core events
[  1451.417] (**) Option "Device" "/dev/input/event4"
[  1451.417] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[  1451.417] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[  1451.417] (II) event4  - AT Translated Set 2 keyboard: device removed
[  1451.432] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[  1451.432] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 13)
[  1451.432] (**) Option "xkb_model" "pc105"
[  1451.432] (**) Option "xkb_layout" "us,ru"
[  1451.432] (**) Option "xkb_variant" ","
[  1451.432] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[  1451.432] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[  1451.433] (II) config/udev: Adding input device ImPS/2 Logitech Wheel Mouse (/dev/input/event8)
[  1451.433] (**) ImPS/2 Logitech Wheel Mouse: Applying InputClass "libinput pointer catchall"
[  1451.433] (II) Using input driver 'libinput' for 'ImPS/2 Logitech Wheel Mouse'
[  1451.433] (**) ImPS/2 Logitech Wheel Mouse: always reports core events
[  1451.433] (**) Option "Device" "/dev/input/event8"
[  1451.433] (II) event8  - ImPS/2 Logitech Wheel Mouse: is tagged by udev as: Mouse
[  1451.433] (II) event8  - ImPS/2 Logitech Wheel Mouse: device set to 400 DPI
[  1451.433] (II) event8  - ImPS/2 Logitech Wheel Mouse: device is a pointer
[  1451.434] (II) event8  - ImPS/2 Logitech Wheel Mouse: device removed
[  1451.464] (II) libinput: ImPS/2 Logitech Wheel Mouse: Step value 0 was provided, libinput Fallback acceleration function is used.
[  1451.464] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input6/event8"
[  1451.464] (II) XINPUT: Adding extended input device "ImPS/2 Logitech Wheel Mouse" (type: MOUSE, id 14)
[  1451.464] (**) Option "AccelerationScheme" "none"
[  1451.464] (**) ImPS/2 Logitech Wheel Mouse: (accel) selected scheme none/0
[  1451.464] (**) ImPS/2 Logitech Wheel Mouse: (accel) acceleration factor: 2.000
[  1451.464] (**) ImPS/2 Logitech Wheel Mouse: (accel) acceleration threshold: 4
[  1451.464] (II) event8  - ImPS/2 Logitech Wheel Mouse: is tagged by udev as: Mouse
[  1451.464] (II) event8  - ImPS/2 Logitech Wheel Mouse: device set to 400 DPI
[  1451.464] (II) event8  - ImPS/2 Logitech Wheel Mouse: device is a pointer
[  1451.465] (II) config/udev: Adding input device ImPS/2 Logitech Wheel Mouse (/dev/input/mouse3)
[  1451.465] (II) No input driver specified, ignoring this device.
[  1451.465] (II) This device may have been added with another device file.
[  1854.349] (II) event3  - Power Button: device removed
[  1854.408] (II) event0  - Power Button: device removed
[  1854.460] (II) event1  - Sleep Button: device removed
[  1854.484] (II) event7  - HP HP Pavilion Gaming Mouse 200: device removed
[  1854.584] (II) event6  - FTCS1000:01 2808:0101 Mouse: device removed
[  1854.656] (II) event9  - FTCS1000:01 2808:0101 Touchpad: device removed
[  1854.716] (II) event5  - Intel HID events: device removed
[  1854.752] (II) event4  - AT Translated Set 2 keyboard: device removed
[  1854.772] (II) event8  - ImPS/2 Logitech Wheel Mouse: device removed
[  1855.486] (II) UnloadModule: "libinput"
[  1855.532] (II) NVIDIA(GPU-0): Deleting GPU-0
[  1855.533] (II) Server terminated successfully (0). Closing log file.
You don't mention trying a fresh install of the system. You do mention that the system worked as anticipated at one time previously but stopped doing so later on.
I would recommend a fresh install if you haven't done so already.
Did you reset CMOS?
Some time ago, it worked, then it didn't. what changed?
Well. I ran out of energy and followed the advice.
I installed Kubuntu. It seems that all the problems have been solved. I hope they don't come back. It's a pity that I lost everything I downloaded to disk.
Thanks to everyone who participated for their help.
