Could use help with a laser printer
I would like to buy this printer. I had good luck with that brand.
I have this cable.
Is that what I need ?
Ha! I thought this would be easy to answer, but doing so required some detective work. According to the Brother specifications for this printer (Specifications | HL‑L2400D | HL‑L2405W | HL‑L2420DW | HL‑L2460DW | HL‑L2460DWXL | HL‑L2865DW), the printer has a "USB Type-B receptacle". That appears to be what you have there, but confirm with the packaging for that cable.
You have the correct cable
