OK so I have been experiencing some major crashing on my work station and it is getting me down because this is way beyond my scope of problem solving..
I came to the desktop this morning after some chores and my screen was all black, but with a cursor, and my graphics tablet display read: "No Device detected." (It's plugged into my GPU - AMD RX 6600 8GB)
I should have pinged the tower or tunneled in from elsewhere to snoop around but I was sort of in a frantic state of mind and it slipped my mind. I just hit the reboot button and when I came into the desktop I read the kern.log and syslog output for the times I experienced the lockup.
I pasted what looked like CPU Hard & Soft lockup errors on Ubuntu Pastebin (which will be up for about a month - happy holidays
Here are the links:
SysLog output: Ubuntu Pastebin
KernLog output: Ubuntu Pastebin
Can someone help me figure out what is causing the crashing?
This happened the other day while I left my Krita drawing and OBS recording my art session. I got up to get some MATE tea and when I came back the system was unresponsive. (probably a diff issue - driver issues with the tablet)
Some system info:
pleiades 5.15.0-56-generic #62-Ubuntu SMP
lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Address sizes: 39 bits physical, 48 bits virtual
Byte Order: Little Endian
CPU(s): 6
On-line CPU(s) list: 0-5
Vendor ID: GenuineIntel
Model name: Intel(R) Core(TM) i5-8600K CPU @ 3.60GHz
CPU family: 6
Model: 158
Thread(s) per core: 1
Core(s) per socket: 6
Socket(s): 1
Stepping: 10
CPU max MHz: 4300.0000
CPU min MHz: 800.0000
BogoMIPS: 7200.00
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts
rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_t
imer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault invpcid_single pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep
bmi2 erms invpcid mpx rdseed adx smap clflushopt intel_pt xsaveopt xsavec xgetbv1 xsaves dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp md_clear flush_l1d arch_capabilities
Virtualization features:
Virtualization: VT-x
Caches (sum of all):
L1d: 192 KiB (6 instances)
L1i: 192 KiB (6 instances)
L2: 1.5 MiB (6 instances)
L3: 9 MiB (1 instance)
H/W path Device Class Description
system MS-7B98 (Default string)
/0 bus Z390-A PRO (MS-7B98)
/0/0 memory 64KiB BIOS
/0/39 memory 32GiB System Memory
/0/39/0 memory 8GiB DIMM DDR4 Synchronous 3200 MHz (0.3 ns)
/0/39/1 memory 8GiB DIMM DDR4 Synchronous 3200 MHz (0.3 ns)
/0/39/2 memory 8GiB DIMM DDR4 Synchronous 3200 MHz (0.3 ns)
/0/39/3 memory 8GiB DIMM DDR4 Synchronous 3200 MHz (0.3 ns)
/0/43 memory 384KiB L1 cache
/0/44 memory 1536KiB L2 cache
/0/45 memory 9MiB L3 cache
/0/46 processor Intel(R) Core(TM) i5-8600K CPU @ 3.60GHz
/0/100 bridge 8th Gen Core Processor Host Bridge/DRAM Registers
/0/100/1 bridge 6th-10th Gen Core Processor PCIe Controller (x16)
/0/100/1/0 bridge Navi 10 XL Upstream Port of PCI Express Switch
/0/100/1/0/0 bridge Navi 10 XL Downstream Port of PCI Express Switch
/0/100/1/0/0/0 /dev/fb0 display Navi 23 [Radeon RX 6600/6600 XT/6600M]
/0/100/1/0/0/0.1 card1 multimedia Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
/0/100/1/0/0/0.1/0 input10 input HDA ATI HDMI HDMI/DP,pcm=7
/0/100/1/0/0/0.1/1 input11 input HDA ATI HDMI HDMI/DP,pcm=8
/0/100/1/0/0/0.1/2 input12 input HDA ATI HDMI HDMI/DP,pcm=9
/0/100/1/0/0/0.1/3 input13 input HDA ATI HDMI HDMI/DP,pcm=10
/0/100/1/0/0/0.1/4 input9 input HDA ATI HDMI HDMI/DP,pcm=3
/0/100/8 generic Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
/0/100/12 generic Cannon Lake PCH Thermal Controller
/0/100/14 bus Cannon Lake PCH USB 3.1 xHCI Host Controller
/0/100/14/0 usb1 bus xHCI Host Controller
/0/100/14/0/1 input3 input Logitech Mechanical keyboard Logitech Mechanical keyboard Keyboard
/0/100/14/0/2 input5 input SteelSeries SteelSeries Rival 310 eSports Mouse Keyboard
/0/100/14/0/9 input7 input Logitech Gamepad F710
/0/100/14/0/a bus HighSpeed Hub
/0/100/14/0/a/1 input 15.6 inch PenDisplay
/0/100/14/1 usb2 bus xHCI Host Controller
/0/100/14/1/3 scsi6 storage My Book 1235
/0/100/14/1/3/0.0.0 /dev/sdc disk 4TB My Book 1235
/0/100/14/1/3/0.0.0/1 /dev/sdc1 volume 3725GiB EFI partition
/0/100/14/1/3/0.0.1 generic SES Device
/0/100/14/1/4 card2 multimedia Logitech StreamCam
/0/100/14.2 memory RAM memory
/0/100/16 communication Cannon Lake PCH HECI Controller
/0/100/17 scsi0 storage Cannon Lake PCH SATA AHCI Controller
/0/100/17/0 /dev/sda disk 256GB ADATA SU760
/0/100/17/0/1 /dev/sda1 volume 238GiB EXT4 volume
/0/100/17/1 /dev/sdb disk 1TB WDC WD1003FZEX-0
/0/100/17/1/1 /dev/sdb1 volume 465GiB EXT4 volume
/0/100/17/1/2 /dev/sdb2 volume 465GiB EXT4 volume
/0/100/1d bridge Cannon Lake PCH PCI Express Root Port #9
/0/100/1d/0 /dev/nvme0 storage ADATA FALCON
/0/100/1d/0/0 hwmon1 disk NVMe disk
/0/100/1d/0/2 /dev/ng0n1 disk NVMe disk
/0/100/1d/0/1 /dev/nvme0n1 disk 512GB NVMe disk
/0/100/1d/0/1/1 /dev/nvme0n1p1 volume 975MiB Windows FAT volume
/0/100/1d/0/1/2 /dev/nvme0n1p2 volume 1952MiB Linux swap volume
/0/100/1d/0/1/3 /dev/nvme0n1p3 volume 57GiB EXT4 volume
/0/100/1d/0/1/4 /dev/nvme0n1p4 volume 416GiB EXT4 volume
/0/100/1f bridge Z390 Chipset LPC/eSPI Controller
/0/100/1f/0 system PnP device PNP0c02
/0/100/1f/1 system PnP device PNP0c02
/0/100/1f/2 printer PnP device PNP0400
/0/100/1f/3 communication PnP device PNP0501
/0/100/1f/4 system PnP device PNP0c02
/0/100/1f/5 generic PnP device INT3f0d
/0/100/1f/6 system PnP device PNP0c02
/0/100/1f/7 system PnP device PNP0c02
/0/100/1f/8 system PnP device PNP0c02
/0/100/1f/9 system PnP device PNP0c02
/0/100/1f/a system PnP device PNP0c02
/0/100/1f.3 card0 multimedia Cannon Lake PCH cAVS
/0/100/1f.3/0 input14 input HDA Intel PCH Front Mic
/0/100/1f.3/1 input15 input HDA Intel PCH Rear Mic
/0/100/1f.3/2 input16 input HDA Intel PCH Line
/0/100/1f.3/3 input17 input HDA Intel PCH Line Out Front
/0/100/1f.3/4 input18 input HDA Intel PCH Line Out Surround
/0/100/1f.3/5 input19 input HDA Intel PCH Line Out CLFE
/0/100/1f.3/6 input20 input HDA Intel PCH Line Out Side
/0/100/1f.3/7 input21 input HDA Intel PCH Front Headphone
/0/100/1f.4 bus Cannon Lake PCH SMBus Controller
/0/100/1f.5 bus Cannon Lake PCH SPI Controller
/0/100/1f.6 eno1 network Ethernet Connection (7) I219-V
/1 power To Be Filled By O.E.M.
/2 input0 input Sleep Button
/3 input1 input Power Button
/4 input2 input Power Button
/5 input22 input UGTABLET 15.6 inch PenDisplay Mouse
/6 input23 input UGTABLET 15.6 inch PenDisplay Keyboard
/7 input24 input UGTABLET 15.6 inch PenDisplay
/8 input25 input UGTABLET 15.6 inch PenDisplay
Thank you so much
