I didn't put this in the hardware part because I'm 100% sure it isn't the hardware.
So I was having issues with processes using too much CPU. It's an intermittent problem. I installed the cpu frequency panel applet a few days ago and just today the laptop slowed down again drastically. The CPU is throttled between 400 and 750 Mhz. It will not go above that speed and I've tried a lot of suggestions online. When I simply set the governor to performance I get no improvement.
I can't find any info online that's really useful. I need to be able to use tlp and whatnot to extend battery life so I can't delete that or just set the CPU to performance and leave it there. Setting it to performance isn't helpful anyway.
The thermals are all fine. I tried an MX-Linux liveUSB I had laying around and the performance was fine.
I'm pretty stumped. If you need any other info please let me know
UPDATE & EDIT
I found out the throttling only happens when the charger is plugged in. When it's unplugged the frequency scaling goes back to normal
I still have to go through the wiki entry but after a reboot things are back to normal. This seems to be an intermittent problem. Any help pinning it down would be appreciated.
EDIT: Laptop came back from suspend and CPU is stuck at less than 800 Mhz despite using the advice in the Arch wiki entry. Rebooted, Cpu still throttled
It seems the CPU gets throttled when the power is plugged in. As soon as I disconnect the AC adaptor, the frequency is normal. As soon as I plug the power back in the CPU goes back to being capped at <800Mhz
I have a really hard time understanding the documents you’ve given me and I don’t really see how most of it can be applied. This isn’t an attack; It’s just a little over my head. I can’t find any info on this phenomenon. anywhere else
Also the battery indicator is giving wildly inaccurate readings. 27 hours is a bit of a stretch for a laptop battery.
Sorry to resurrect this old thread. I'm trying to do a BIOS update from the software center but I'm getting an error saying the laptop needs to be plugged in. It is, the indicator on the taskbar indicates AC power but it's not charging. I've had it plugged in for over 2 hours with both the laptop on and turned off and the level hasn't changed at all. I haven't fiddled with any settings in the BIOS. I looked in the BIOS and it showed the same lack of charging. Both the taskbar indicator and the BIOS show the same level of charge. I'm using a non-Dell charger but i have been for over a year without a problem. I checked it with a multimeter and it seems fine.
EDIT: So I upgraded to the 4.18 kernel and the CPU throttling issue went away... for now.... I still can't update the firmware and the battery still isn't charging
