For a few days now i have been trying to start ubuntu and other linux based os from a pen drive without any luck. What happen was that my HD crash and i wanted to start by the pen drive in a non persistent way.
I have installed Rufus and burn a few images for testing and the only operating system that did do anything was CentOS. All the rest wasn’t possible to autostart will booting.
What seems to be the problem? I will have a shot with the Ubuntu Mate but i expect that the result will be the same. Nothing. Any sugestions?
Yes, i have done all the steps with other iso images. Simply it doesn’t boot, only CentOS works but after a few moments loading the kernel it crashes. I will give it a try with this mate version and reply back…
It would be advantageous to know if your present ‘crashed’ hard drive has an efi boot process. If it does, this impacts how you should write an ubuntu iso to a flash drive and expect it to boot. See rufus directions.
Aside from Rufus i have tried other program such as YUMI or MultiBoot and they didn’t work either. This distro Ubuntu Mate doesn’t even burn the image, something with a .sys file that is downloaded but fail to burn.
I have tried so far:
CentOS-6.9-x86_64-LiveDVD
kali-linux-2016.1-i386
KNOPPIX_V7.0.5CD-2012-12-21-EN
linuxmint-17.1-cinnamon-32bit
linuxmint-18.2-cinnamon-32bit
pipplware_v6.0
slacko-6.3.0
ubuntu-14.04.5-desktop-i386
ubuntu-16.04.3-desktop-amd64
and
ubuntu-mate-16.04.3-desktop-i386
