Cryptsetup - sda3_crypt is still in use at shutdown and reboot
Hi!
When I shutdown or reboot my system, systemd (cryptsetup) says
"cryptsetup - sda3_crypt is still in use... device is busy".
Shutdown and reboot are fast, nothing hangs at the shutdown or reboot procedure.
cryptsetup: "2:2.1.0-1ubuntu1"
I've changed in the file: "/lib/cryptsetup/cryptdisks-functions":
Removes all mappings in crypttab
do_stop() {
dmsetup mknodes
log_action_begin_msg "Stopping $INITSTATE crypto disks"
crypttab_foreach_entry _do_stop_callback
log_action_end_msg 0
to
do_stop() {
dmsetup remove_all
local dst src key opts opencount major minor
dmsetup mknodes
...but that didn't help.
Is there a way to fix that or hide the message from cryptsetup?
System: U-M 19.04
tl;dr: append the x-initrd.attach option in /etc/crypttab to the line starting with sda3_crypt
Explanation:
This will make systemd aware that sda3_crypt contains the root partition and will postpone closing sda3_crypt, see also https://www.freedesktop.org/software/systemd/man/crypttab.html#x-initrd.attach
