Hi there!
ctrl alt 2 doesn’t work for some reason, i use the nordic qwerty layout. How can i fix this?
ctrl alt t works fine btw
I have checked it and i don’t know how this could help me in any way, all of the ctrl+alt+a number does not work.
Create your own settings? (Add). ![]()
Im new to linux, how can i do this. I know i need some code but i dont know the language
you don’t need code, click on the “Add” button and press buttons for what you want them to do!.
https://help.ubuntu.com/16.04/ubuntu-help/keyboard-shortcuts-set.html
I still need a command, and the links you provided are only about launching applications. I need to make ctrl alt 2 type @.
Hi @Asger_Lenz,
is this your layout?:
Press AltGr + 2 and you should get the @ symbol!. ![]()
On my board (QWERTZ), I press AltGr + q for the @ symbol!. ![]()
Thanks, it worked! I just have to get used to the new layout i guess. PS: This is my keyboard layout
Great, please put a tick in the best answer box to mark it as solved so it helps others.
