Cupertino Theme
I am currently using the Cupertino theme and by default it has the plank dock on the bottom. However, I accidentally took off the plank settings on the task bar and an unable to change the settings.
Does anyone know how to retrieve it back? or be able to get into the settings?
Thanks!
Press ALT+F2 to open the Run Application window, then type either:
For MATE Tweak (to change layouts):
mate-tweak
Or for Plank's settings:
plank --preferences
That worked, thank you so much!!
You can edit the configuration file by this command:
gksudo gedit ~/.config/plank/dock1/settings
