Customizing "console" setting?
Is it safe to set the parameter values used in
/usr/share/console-setup/keyboard
current contents:
# KEYBOARD CONFIGURATION FILE
# Consult the keyboard(5) manual page.
XKBMODEL=pc105
XKBLAYOUT=us
XKBVARIANT=
XKBOPTIONS=
BACKSPACE=guess
to the same values assigned in
/etc/default/keyboard
current contents:
#XKBMODEL="pc105"
# Hewlett-Packard NEC SK-2500 Multimedia
# Description string from:   /usr/share/console-setup/KeyboardNames.pl
XKBMODEL="hp250x"
XKBLAYOUT="us"
XKBVARIANT=""
#XKBOPTIONS=""
XKBOPTIONS="compose:ralt,terminate:ctrl_alt_bksp,grp_led:caps,grp_led:num,grp_led:scroll,grp:alts_toggle"
# If you don't want to use the XKB layout on the console, you can
# specify an alternative keymap.  Make sure it will be accessible
# before /usr is mounted.
# KMAP=/etc/console-setup/defkeymap.kmap.gz
BACKSPACE="guess"
#text for language
gsettings set org.mate.peripherals-keyboard-xkb.indicator true
#flag for language
gsettings set org.mate.peripherals-keyboard-xkb.indicator show-flags true
gsettings set org.mate.peripherals-keyboard-xkb.kbd layouts "['us','ca','ca','ca']"
gsettings set org.mate.peripherals-keyboard-xkb.kbd variants "[,,'eng','multix']"
#/usr/share/X11/xkb/types
Or must I exclude the gsettings commands ?
