does the color of these menu tabs is customizable?(red arrows)
Yes you can edit the top panel's color in the panel preferences.
Not sure about this menu.
You can use oomox if you're into heavy color customization. materia-theme has an install script that allows you to select your own colors as well.
I was not aware of oomox. Thanks for that link.
thanks, that's helpful info.
