I am having problems with the daily builds not running,asking for user id and passwords and in general not even booting up after choosing try without installing ???
did you use a disk and follow this advice?:
@kuvanito Make sure you have that latest daily, built a few hours ago, because the issues you describe have been fixed
yeap,latest build was corrected also Rufus with Windows has given me some issues but Unetbootin keeps on being the Champion
my dear friend wolfman I stopped buying cd’s and dvd’s longggggggggggg time ago
I actually went back to using re-burnables (disks) as Unetbootin kept doing things wrong ( I told it not to but it did so anyway!
), although it takes a tad longer, I seem to have fewer if no problems doing it that way!.
you are right,the burn is 99% always successful,nice day to all
One tool I won’t use as it sucks (imo), is Startup Disk Creator, I have never ever ever had made a successful bootable USB stick using that app, Unetbootin is waaaaaaay better than SDC, that said, I tend to use re-burnables now even though it takes longer to install!.
