Darkcoin mining - cpuminer
I have problem with compiling cpuminer from this tutorial [Noob-Proof] How To Install Cpuminer and Mine Darkcoin under Linux/Ubuntu
I have those errors
f4rr3llino@b0tnet:~$ cd darkcoin-cpuminer-1.2c
f4rr3llino@b0tnet:~/darkcoin-cpuminer-1.2c$ sudo chmod +x autogen.sh
f4rr3llino@b0tnet:~/darkcoin-cpuminer-1.2c$ sudo ./autogen.sh
configure.ac:13: installing './compile'
configure.ac:4: installing './config.guess'
configure.ac:4: installing './config.sub'
configure.ac:6: installing './install-sh'
configure.ac:6: installing './missing'
Makefile.am:14: warning: 'INCLUDES' is the old name for 'AM_CPPFLAGS' (or '*_CPPFLAGS')
Makefile.am:18: warning: source file 'x2/sha2.c' is in a subdirectory,
Makefile.am:18: but option 'subdir-objects' is disabled
automake: warning: possible forward-incompatibility.
automake: At least a source file is in a subdirectory, but the 'subdir-objects'
automake: automake option hasn't been enabled. For now, the corresponding output
automake: object file(s) will be placed in the top-level directory. However,
automake: this behaviour will change in future Automake versions: they will
automake: unconditionally cause object files to be placed in the same subdirectory
automake: of the corresponding sources.
automake: You are advised to start using 'subdir-objects' option throughout your
automake: project, to avoid future incompatibilities.
Makefile.am:18: warning: source file 'x2/sha2-arm.S' is in a subdirectory,
Makefile.am:18: warning: source file 'x2/sha2-x86.S' is in a subdirectory,
Makefile.am:18: warning: source file 'x2/sha2-x64.S' is in a subdirectory,
Makefile.am:18: warning: source file 'x2/scrypt.c' is in a subdirectory,
Makefile.am:18: warning: source file 'x2/scrypt-arm.S' is in a subdirectory,
Makefile.am:18: warning: source file 'x2/scrypt-x86.S' is in a subdirectory,
Makefile.am:18: warning: source file 'x2/scrypt-x64.S' is in a subdirectory,
Makefile.am:18: warning: source file 'x5/aes_helper.c' is in a subdirectory,
Makefile.am:18: warning: source file 'x5/luffa_for_sse2.c' is in a subdirectory,
Makefile.am:18: warning: source file 'x5/shavite.c' is in a subdirectory,
Makefile.am:18: warning: source file 'x5/cubehash_sse2.c' is in a subdirectory,
Makefile.am:18: warning: source file 'x5/vect128/nist.c' is in a subdirectory,
Makefile.am:18: warning: source file 'x5/vect128/vector.c' is in a subdirectory,
Makefile.am:18: warning: source file 'x5/echo.c' is in a subdirectory,
Makefile.am: installing './depcomp'
f4rr3llino@b0tnet:~/darkcoin-cpuminer-1.2c$ sudo ./configure CFLAGS=¨-03¨
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking target system type... x86_64-unknown-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking for style of include used by make... GNU
checking for gcc... gcc
checking whether the C compiler works... no
configure: error: in /home/f4rr3llino/darkcoin-cpuminer-1.2c': configure: error: C compiler cannot create executables See config.log' for more details
Can someone help me why command make is not working?
