I would be grateful if you could point me to a guide for debugging caja. I've built it from the source, it starts, but 'caja' wrapper brings up the window and exits immediately.
I tried attaching to the running process using CLion, then it doesn't find the symbols. And the running process is '/usr/bin/caja' even though this file doesn't even exist on my machine. So there's something fishy going on.
Best regards,
Andrij
