So, I was trying to install firefox 81 on Ubuntu MATE 20.04. When I was trying to, it was saying libc6 needed 2.32 but I had 2.31 installed. So I decided to look up where 2.32 was an attempt to install the .deb package. I found it and tried to install it but it said something along the lines of that it wouldn't allow reconfiguration for locales libc6 2.31. I thought it would fix installing with sudo dpkg -i --auto-deconfigure libc6_2.32-0ubuntu3_armhf.deb and I think I screwed up.
Now these are broken and when I try to reinstall them, it wants to remove all these critical packages:
https://pastebin.com/uQgDLKpX
What can I do? I'm not sure if this is a thing that can be fixed. I can't update, upgrade, remove, or reinstall anything.
