Default Key bindings
In Control Center -> Keyboard shortcuts it should be possible to find the keyboard mapping/binding.
When I look into the list I can’t see the actual key for most of the functions which needs to be pressed:
e.g:
Launch Web browser XF86WWW /* which key is that ?
or
Home folder XF86Explorer /*which key is that ?
one example that works they way expected:
Lock screen ctrl-alt-L /* This one really works !
Where can I find the mapping from XF86something to the real key ?
Those are special buttons , If your keyboard has them you can use them : Like the www button on most keyboards , media keys on difirent kind of keyboards for controling the volume .
