I would like to clean unneeded folders under /usr/share/doc/.
I assume that it is safe to delete the tor folder since I no longer have the program.
Is is also safe to delete empty folders?
To my knowledge, /usr/share/doc
is a directory which is rarely used by programs themselves; it's for users to look in for documentation. I have a slim Ubuntu MATE 18.04 and an ultra slim Linux From Scratch here which both lack the /usr/share/doc
directory. So I believe that yes, you can delete empty directories and the tor
directory if you desire.
So, how did you get a system without the /usr/share/doc directory?
Also, to rid yourself of unwanted garbage on your PC, install Bleachbit to get rid of it !..
sudo apt install bleachbit
I deleted the directory. Bam. OK, not the perfect solution, but it works.
That whole directory is only 68 Mb on my system.
Too risky to delete the whole thing.
