I am trying to get rid of Flat-Remix-GTK, both themes and icons.
I have looked up in the internet but could not find how to.
I tried in the terminal
sudo add-apt-repository ppa:daniruiz/flat-remix -r
and then
sudo apt-get remove flat-remix-gnome
or
sudo apt-get remove flat-remix-gs-theme
with the same result:
Unable to locate package flat-remix-gnome
or
Unable to locate package flat-remix-gs-theme
I wonder if anybody could help me to get rid of the theme/icons. It did not install well but the fact is that I did not like what I got - neither the theme/themes nor the icons.
Many thanks, Apollonius. I tried your suggestion and got:
lostados@lost-mac:~$ sudo apt-get --purge remove flat-remix
[sudo] password for lostados:
Reading package lists... Done
Building dependency tree
E: The package flat-remix-gnome needs to be reinstalled, but I can't find an archive for it.
lostados@lost-mac:~$ sudo apt-get install flat-remix-gnome
The following packages will be upgraded:
flat-remix-gnome
1 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
1 not fully installed or removed.
Need to get 0 B/3.506 kB of archives.
After this operation, 39,6 MB of additional disk space will be used.
(Reading database ... 389725 files and directories currently installed.)
Preparing to unpack .../flat-remix-gnome_3.32.2-2_amd64.deb ...
Unpacking flat-remix-gnome (3.32.2-2) over (3.32.2-2) ...
dpkg: error processing archive /var/cache/apt/archives/flat-remix-gnome_3.32.2-2_amd64.deb (--unpack):
trying to overwrite '/usr/share/themes/Flat-Remix/gnome-shell/assets/calendar-arrow-left.svg', which is also in package flat-remix-themes 2.1-r1~cosmic~NoobsLab.com
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
update-alternatives: error: no alternatives for gdm3.css
dpkg: error while cleaning up:
new flat-remix-gnome package post-removal script subprocess returned error exit status 2
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
When I tried to uninstall, I got:
The following additional packages will be installed:
flat-remix-gnome
The following packages will be REMOVED:
flat-remix*
flat-remix-gnome
1 upgraded, 0 newly installed, 1 to remove and 1 not upgraded.
After this operation, 294 MB disk space will be freed.
Do you want to continue? [Y/n] y
How and from where did you install it in the first place? Because how you remove it will depend on that...
Always remember how you installed something so that you can remove it later if necessary, otherwise mess like this will happen.
It seems you installed it from a noobslab PPA. So try uninstalling that: sudo apt-get --purge remove flat-remix-themes.
And then remove the PPA. See if that works.
Apollonius & pavlos_kairis,
Thank you very much. I think you were enormously patient with me and I did appreciate that. I am afraid I cannot say how the problem arose. I got the how-to-install from NoobsLab but cannot say what went wrong.
In the end I ran out patience and did a clean install of Ubuntu Mate 19.04. I hesitated a lot as the PC was running very, very smoothly. Lots of hard work but I think it was worthwhile: UM is now running even better. And faster...
Many thanks again.
Always happy to help, don't mention it.
Couple of years ago I was also new to Linux and I've always found the communities very helpful whenever I needed them. I wouldn't be here trying to help you out if it wasn't for them...
If you want to enjoy working with and using Linux, you have to be patient; you have to search and research online to get to the root of your problem, it's always exciting and an amazing feeling when you solve your own problem!
