I would like to find out the temp of my Gpu.
Kaveri [Radeon R7 Graphics]
k10temp-pci-00c3
Adapter: PCI adapter
temp1: +41.4°F (high = +158.0°F)
(crit = +176.0°F, hyst = +174.2°F)
radeon-pci-0008
temp1: +41.0°F (crit = +248.0°F, hyst = +194.0°F)
fam15h_power-pci-00c4
power1: N/A (crit = 65.19 W)
it8620-isa-0228
Adapter: ISA adapter
in0: +1.04 V (min = +0.00 V, max = +3.06 V)
in1: +1.54 V (min = +0.00 V, max = +3.06 V)
in2: +2.02 V (min = +0.00 V, max = +3.06 V)
in3: +2.04 V (min = +0.00 V, max = +3.06 V)
in4: +2.04 V (min = +0.00 V, max = +3.06 V)
in5: +2.23 V (min = +0.00 V, max = +3.06 V)
in6: +2.23 V (min = +0.00 V, max = +3.06 V)
3VSB: +3.34 V (min = +0.00 V, max = +6.12 V)
Vbat: +3.17 V
fan1: 1804 RPM (min = 10 RPM)
fan2: 0 RPM (min = 0 RPM)
fan3: 561 RPM (min = 0 RPM)
fan4: 0 RPM (min = 0 RPM)
fan5: 0 RPM (min = 0 RPM)
temp1: +96.8°F (low = +260.6°F, high = +260.6°F) sensor = thermistor
temp2: -198.4°F (low = +260.6°F, high = +260.6°F) sensor = disabled
temp3: +66.2°F (low = +32.0°F, high = +140.0°F) sensor = Intel PECI
temp4: +111.2°F
temp5: +113.0°F
temp6: +113.0°F
intrusion0: ALARM
