How do I do this via the terminal?
The track pad should only be for moving the mouse as my left click button is 0.5cm away for me to click!
I keep accidentally clicking when just trying to move my cursor!
track pad click is dangerous!
Hi @benzmuircroft, Go to the mouse settings - there should be a touchpad tab where you can disable mouse clicks. I agree - it can be dangerous.
Hope this gets it.
See - https://askubuntu.com/questions/118892/how-do-i-disable-touchpad-tap-to-click
But you can specify this via System, Preferences, Mouse -
Or if you prefer, use dconf editor -
Edit: Ninjaed!!
[quote=“mdooley, post:3, topic:15538”]
Ninjaed!!
[/quote]Only by a few minutes
but I don’t have a touchpad on this desktop to grab the nice pictures.
I assume the OP wants to bind keyboard keys to quickly enable and disable via keyboard.
Disable click (track pad) via Terminal:
gsettings set org.mate.peripherals-touchpad tap-to-click false
Enable:
gsettings set org.mate.peripherals-touchpad tap-to-click true
Check status:
gsettings get org.mate.peripherals-touchpad tap-to-click
System, Preferences, Mouse (I have no touchpad tab)
edited dconf disabled tap-to-click, tap-button-one-finger set to 0, same with all other gestures set to zero
restarted but no change
false
but I can still tap to click!
grrr lol crazy!
there is no touchpad tab
I have a theory https://askubuntu.com/questions/987134/trackpad-disable-buttons-but-keep-cursor-movements
Not sure if it applies to your case but an absence of the Touchpad tab under Mouse settings is always fixed for me with sudo apt-get install xserver-xorg-input-synaptics then a log-out & in/reboot.
no change after restart
Hopefully someone with more expertise can add more. I can offer what I’m sure is the basic problem - the touchpad hardware is not recognized and has defaulted to a basic mouse driver (ImPS/2 Generic Wheel Mouse). I’m guessing the reason it works at all is because it does behave as a basic mouse.
If you search for “ImPS/2 Generic Wheel Mouse” you will see this problem is quite common. It’s very specific to hardware so be sure and seek solutions for your specific system.
I done a tone more attempts here https://unix.stackexchange.com/questions/411467/turning-off-tap-to-click-and-touchpad-scrolling-ubuntu-mate
ended up putting tape on the scrolling part of the track pad so i can feel when my finger is about to hit!
also i set drag and drop threashold to zero and double click-timeout to 50%
its not ideal
lol tape
apt-get install tape
dudes,
love u lots but, this touchpad issue is a big deal plus alsamixer wont even load so i have no sound…
I’m out!
I will switch to plain Ubuntu tomorrow and probly never come back to mate!
touchpad tab is missing in settings > mouse … Ive gone through everything on google! spent the whole day!
I’m done!
close thread! x
