I installed Ubuntu-Mate on a Raspberry Pi, since I am using it for robotic stuff and needed extra resources so I disabled lightdm (which improved performance a lot) with sudo systemctl disable lightdm. Since then I can't reproduce sounds with it (which I need). Not even aplay works.
If I start lightdm again, sound works again. However performance drops down.
I am almost sure ether lightdm or mate (which is started by lightdm) do something with ether alsa or pulseaudio, I just have no idea what.
Any idea?
edit:
the user is already on audio, pulse and pulse-access groups
Welcome to the Ubuntu MATE community, @fcolecumberri! I'm sure you'll get some ideas from others with more expertise in this area.
For ordinary Ubuntu I was needed to place my user into audio group.
Try the following command
sudo usermod -a -G audio $USER
and reboot.
The user is already on the audio group and still doesn't work. Also sudo aplay doesn't work aether, so I don't think it's a permissions issue.
Ok, I figured it out, when I disabled lightdm, I connected with ssh -Y <user>@<hostname>, the -Y forward the xservice. For some reason pulse uses the xservice so there were problems. I still don't understand why or how or if it is possible to forward the xservice without messing with the audio, but if I connect without the -Y flag, everything works fine.
