I want to set my WIFI so it wll not turn off when I close the lid.
In Ubuntu its
/etc/pm/power.d/wireless_power_management_off
but that setting does not exist in Mate.
Where you guys hide it ![]()
In Ubuntu its
Hey man,
I am also experiencing this too…can you please tell me how did you fix it? Really need this :D. Here is a upvote too haha.
It turns out wifi power management is off by default and my occasional lack of wifi after suspend is due to something else. Could be something to due with my wlp setup.
You can check your status in terminal:
iwconfig
The output will look like this:
wlp3s0 IEEE 802.11 ESSID:"xxxxxx.xxx"
Mode:Managed Frequency:2.462 GHz Access Point: 00:02:6F:FB:BE:4E
Bit Rate=48 Mb/s Tx-Power=15 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:off
Link Quality=54/70 Signal level=-56 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:2675 Missed beacon:0
On my Raspberry Pi 3 B+ running Ubuntu Mate 18.04 LTS the wifi power management is always on after I boot up. I turn it off with sudo iwconfig wlan0 power off after each reboot. The scripts I've looked up and tried so far don't work. There's so many. It's crazy.
Me again. I found this on another website and it worked:
Open this file with your favorite text editor, I use nano here:
sudo nano /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
By default there is:
[connection]
wifi.powersave = 3
Change the value to 2 . Reboot for the change to take effect.
Possible values for the wifi.powersave field are:
NM_SETTING_WIRELESS_POWERSAVE_DEFAULT (0): use the default value
NM_SETTING_WIRELESS_POWERSAVE_IGNORE (1): don't touch existing setting
NM_SETTING_WIRELESS_POWERSAVE_DISABLE (2): disable powersave
NM_SETTING_WIRELESS_POWERSAVE_ENABLE (3): enable powersave
