Looking at a video file's properties using Caja, we see the following reporting the FPS value as 25:
Opening that file in HandBrake, the initial Summary panel usually reports the file's properties as well but, instead, it seems to be reporting incorrectly, showing a value of 30 FPS:
Can anyone confirm that the Caja-reported value is the correct one and that, somehow, a bug has found its way into HandBrake?
