Hi Steve,
Until you provide some specs on your gear, the following tips may of some help:
To troubleshoot:
You probably should uninstall all your displaydrivers first, because displaydrivers are already build in into the kernel.
For instance: nVidia, AMD and Intel GPU's work out of the box.
If it doesn't, you probably have a totally different issue than the drivers itself.
Updating the kernel while having installed a 3rd party videodriver directly from the vendor can potentially result in a non-working display because the old driver is not compatible with the new kernel and therefore must be either updated or recompiled.
3rd party drivers from the repository will recompile automatically after a kernelupdate, but even then: it can happen that the system updates to a new kernel while the (probably closed source) 3rd party driver is not updated yet, in which case your display won't work until that is fixed.
Besides the fact that the build-in drivers are often of higher quality and compatibility and hassle-free , you might have reasons to install 3rd party drivers.
So when should you install drivers then ?
If you have installed an AMD card and you really need OpenCL
If you are stuck with an nVidia GPU and either:
- you need CUDA
- you want to do some heavy gaming and need high speed performance
So you can either:
- keep the driver that worked and roll back to the previous kernel
or
- uninstall all displaydrivers and use the build-in kerneldrivers
or
- wait until the 3rd party videodriver gets updated.
So what to do in the future when using a 3rd party driver ?
Lock your kernelversion until you are sure that the 3rd party driver is also updated.
I hope this helps a bit, please let us know how you fare.
