I'm not sure where to start with this one but here's what I have:
Ubuntu Mate 22.04.1
Dell XPS17 with Nvidia as follows:
description: 3D controller
product: GA107M [GeForce RTX 3050 Mobile]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
logical name: /dev/fb0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list rom fb
configuration: depth=32 driver=nvidia latency=0 mode=3840x2400 visual=truecolor xres=3840 yres=2400
resources: iomemory:600-5ff iomemory:610-60f irq:204 memory:a9000000-a9ffffff memory:6000000000-60ffffffff memory:6100000000-6101ffffff ioport:3000(size=128)
*-display
description: VGA compatible controller
product: TigerLake-H GT1 [UHD Graphics]
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 01
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom fb
configuration: depth=32 driver=i915 latency=0 resolution=3840,2400
resources: iomemory:610-60f iomemory:400-3ff irq:187 memory:618c000000-618cffffff memory:4000000000-400fffffff ioport:4000(size=64) memory:c0000-dffff memory:4010000000-4016ffffff memory:4020000000-40ffffffff
Normally I run at UHD 3840x 2400, however today I inadvertently connected to and additional pair of monitors via USB, and now my primary display has artifacts I can't get rid of, such as plank in the middle of the screen. It's as if there is an HD display within the UHD display in the top left corner.
Has anyone else seen this behaviour?
Link to display image: Screenshot-at-2022-11-15-10-07-53 — ImgBB
Regards
Ian
