There is some Gnome extensions that I think are useful. Are Gnome extensions compatible with Ubuntu Mate 17.04?
No, the extensions are for GNOME Shell, which was a new part of GNOME 3, so not forked into MATE or incorporated later.
This is one of the main problems with linux, seen as an operating system to support end-user apps, which are mostly GUI in nature.
This supports this, that supports that, there’s no skeleton to support it all, so the thing just flops around like a chicken.
That’s my contribution for the day, are you helped?
(Didn’t think so, i’ll try harder tomorrow.)
Thanks for Sharing - But i'll like to say again : There is anywhere else where you can choose, custom and share your operating system. How many desktops environments are available on Linux ? How many ways of computing ?
Most of softwares are available in any DE and most distro. Gnome extensions are more like part a of a specific DE which is Gnome.
What do like to do for instance that makes you want to install Gnome Extensions ? May i ask ?
If you want GNOME extensions with the Ubuntu base of software, use Ubuntu GNOME instead. Pretty simple, yeah?
not the least bit simple imo
Now you’re just being subjective. Ubuntu GNOME would give everything the OP was seeking, sans the familirity stuff that comes with Ubuntu MATE.
Yes, but the effort required of the user, in order to migrate from what is installed by default, to the gnome equivalents, is what i am saying is non-trivial, not-common-knowledge, not-simple. Unless there is perhaps some easy method of conversion, a script perhaps, which i think is doubtful, due to lack of demand. I’m not saying it can’t be done, just that it isn’t as simple as it can be made to sound. fwiw.
Do you not know there is an official flavour of Ubuntu with the GNOME desktop?
“you” who, the OP or me?
I’m not sure why, if somebody wanted gnome, he’d be using Ubuntu instead of Debian.
Whatever, i hope the OP gets his/her situation solved acceptably. I’m perfectly happy with Ubuntu-MATE, though Ubuntu itself could use some serious fixing imo (and heck no, i’m not volunteering).
I much prefer MATE, and have just returned to it having tried to use Gnome, but it would be great to be able to use the Gnome extension Vitals (in particular, the ability to show the current battery drain in watts, but also I like it's extensive number of monitored elements and its configurability).
Hi jon,
This is probably as close as you can get:
It misses out on some info, but on the other hand, some info in Vitals is unreliable (like batterydrain in watts, which is a pretty inaccurate derivative estimate)
Anyway, if you like this gadget:
sudo apt install psensor
Hi @tkn , I like your theme...can u share it? What is its name?
Ambiant-MATE-Dark (actually Ambiant-MATE-Dark-Red) with a custom red/black background i intentionally searched for
https://wallpapersnap.com/wallpapers/full/4/1/6/24859.jpg
(hmm..it looks like the site is constantly changing the URL-path for this picture, anyway you should be good with this link:
Msi Wallpaper on Wallpapersnap
and search for it)
Sadly the Ambiant themes are no longer in the repository but thanks to @lah7, hosting the Ambiant themes including all color variants, we still have the luxuary to be able to install it.
Please visit this link for a bit of background and the commands to add the PPA
Is there any way to use this extension on mate without installing full Gnome? Or is there any alternative? Thanks
From the gnome extensions pages:
To control GNOME Shell extensions using this site you must install GNOME Shell integration that consists of two parts: browser extension and native host messaging application.
Compatibility (no dependencies required):
Compatibility with dependencies:
Not all models are comaptible. Please read about the compatibility and dependencies of your device on github link below.
From a commenter: It's the same with my Lenovo Ideapad. I used to set this via /sys/bus/platform/drivers/ideapad_acpi/VPC2004:00/conservation_mode.
It supports only the states 1 or 0 (on or off). In my case it limits charging to 60%, which is better than nothing.
This sounds very specific, relying on your browser as a browser addon and only on certain makes and models of computers. Even then it does not work 100%. It sounds very much like a work in progress to me.
As far as I know, they don't. GNOME and MATE are distinct desktop environments, each with its own underlying architecture, libraries, and extension system. They are built using different toolkits (GTK3 for GNOME, and GTK2/GTK3 for MATE).
Hi, @MaksimMM and welcome to the Ubuntu MATE Community!
No, that is absolutely impossible.
Gnome extensions are code dependent on Gnome shell, which is the core of the Gnome desktop environment.
Therefore it will not work on any onther desktop environment (KDE, MATE,Moksha,XFCE,LMDE,LXDE, ... )
