Hello all, since I recently started to optimize my old laptop a bit more having a bit of spare time I was wondering would installing TLP or any similar app help me with battery longevity since I still have a decent 4-6 hours on a battery I got with my laptop when I bought it in 2018ish.
It's Acer Aspire i-5 8th gen with intel 620UHD and 8GB ram
My battery info are as stated in terminal:
native-path: BAT1
vendor: LG
model: PABAS0241231
serial: 41167
power supply: yes
updated: Sun 18 May 2025 02:56:42 PM CEST (1 seconds ago)
has history: yes
has statistics: yes
battery
present: yes
rechargeable: yes
state: discharging
warning-level: none
energy: 34.9296 Wh
energy-empty: 0 Wh
energy-full: 36.4648 Wh
energy-full-design: 48.944 Wh
energy-rate: 8.0408 W
voltage: 16.166 V
charge-cycles: N/A
time to empty: 4.3 hours
percentage: 95%
capacity: 74.5031%
technology: lithium-ion
icon-name: 'battery-full-symbolic'
History (charge):
1747572972 95.000 discharging
History (rate):
1747573002 8.041 discharging
1747572972 7.448 discharging
1747572942 5.670 discharging
1747572912 4.317 discharging
There is a high probability that you are already using tlp in default configuration. Ubuntu MATE comes with the tlp package preinstalled.
https://cdimage.ubuntu.com/ubuntu-mate/releases/24.04.2/release/ubuntu-mate-24.04.2-desktop-amd64.manifest
There is also laptop-mode-tools. You can't run tlp and laptop-mode-tools at the same time, both have their good points and faults.
Battery life on Linux has been an issue for years. I would think something that saves battery life would be worthwhile to run.
If you are having real issues powertop can help you track down the power vampire.
Yes you are right! I did not even know that it was a thing! Thank you a thousand times you've just made my day!
I checked tlp and it indeed is working ! Now it all makes much more sense in retrospect since I was surprised that my old battery still worked as I remember long time ago when I had a HP laptop with brand new windows 7 back in the day it was a bigger and better battery than this one in Acer but it died on me in under 5 year span for some reason
Thank you for your suggestion - I was actually just checking since I was wondering how come this setup I have of Ubuntu MATE is so gentle on my battery considering the age and my usage (mostly browsing, writing and occasional old RTS game)
I will surely check out and learn more about the link you've send me - I was always interested in optimizing my laptop to run as smoothly as possible since it's only thing I have for now so I don't want it do die on me until I buy a new desktop by the end of the year haha
A word of warning about powertop; I found that it never 'calibrated' particularly well, and would often attribute high usage to devices that weren't drawing much/any power (i.e. even when the device was disabled entirely, it would report high usage).
I haven't tested this yet, but I have heard that - for those with AMD CPUs - enabling the AMD p-state driver (and governor) can yield an improvement in power consumption. The issue for me is that I need to do some whacky BIOS stuff (to enable CPPC - see e.g. Linux battery life on an Asus G14), so it's off the cards until I can 'risk' the time repairing my laptop if it goes bad.
