Context:
Filesystem has been tagged by
tune2fs
for auto-trigger offsck
after mount-count "reboots". -
External USB backup disk is plugged in, but
/etc/fstab
specifies "no auto-mount" and the mount point is non-standard, namely "/site", specifically to "mask" all such drives from the auto-mounting services.
Anybody know for sure if the fsck triggered by the boot process will
- [1] allow the OS on the primary boot disk to proceed with the Desktop Manager, allowing a user session login, even if the fsck on the external drive is not finished,
or
- [2] even if no auto-mount for that attached external USB drive, the auto-triggered boot-time fsck on the USB will prevent the User from obtaining and performing a login?
If [1], if I enter a separate command to mount the USB-based partition,
does the OS handle the process "gracefully", allowing the fsck to finish before mounting, or
does it force fsck to abandon by interrupting it, or
does the fsck process "break", because the partition is now mounted and being "modified" during the fsck process.
