I notice that when I still have running applications (particularly Steam) while shutting down the system, the desktop color scheme falls back to Raleigh, here's a screenshot:
I found out in /usr/share/themes/Raleigh/gtk-2.0/gtkrc it says:
# This theme is the default theme if no other theme is selected.
so I'm guessing it's intentional(?)
Now, as a workaround I replaced everything in Raleigh folder with AmbiantMATE, I also renamed some stuffs to "Raleigh" so it would work. It only works for the color scheme though, I still don't know how to fix those icons.
Lately I also notice it behaves the same when starting up the system (Raleigh theme loaded first, then my tweaked theme), it wasn't like that before, I don't know what causes it. Frankly it's quite annoying to see stuffs keep falling back to Windows95 vibe, no offense.
I think it would be nice if it falls back to my Ambiant by default, or even better, don't fallback at all.
Thanks
