Hi, it would be great if someone can help me to configure DP-301P+. I installed it before on Ubuntu studio but I do not remember how
I want a step by step solution. I have Fritzbox and printer is HP 3030.
I hope you can help
According to the factory pdf, the install cd has linux install on it and from what I see the cd is still available for download.
ftp://ftp2.dlink.com/PRODUCTS/DP-301PPLUS/REVA/DP-301PPLUS_MANUAL_1.00_EN.PDF
Could you of been using the CUPS web interface before?
And ran across this:
Thank you.
I downloaded this file: dp301p_v370_build_18.bin, but I doe not know how to use or start it.
Thanks for helping.
I would think that its the the one under SoftWare that is the install CD. Not the download under FirmWare. Not having one, this is my best guess.
I tried
P { margin-bottom: 0.08in; }
sudo ./dp301p_v370_build_18.bin
and got these (a lot of) lines:
./dp301p_v370_build_18.bin: 1: ./dp301p_v370_build_18.bin: StevenWu$�,�G�b��엟��Message: not found
./dp301p_v370_build_18.bin: 2: ./dp301p_v370_build_18.bin: ReGetIndex: not found
./dp301p_v370_build_18.bin: 3: ./dp301p_v370_build_18.bin: RefreshTime: not found
./dp301p_v370_build_18.bin: 4: ./dp301p_v370_build_18.bin: DownloadTime: not found
./dp301p_v370_build_18.bin: 5: ./dp301p_v370_build_18.bin: DownloadStatus: not found
./dp301p_v370_build_18.bin: 6: ./dp301p_v370_build_18.bin: EntryNo: not found
./dp301p_v370_build_18.bin: 7: ./dp301p_v370_build_18.bin: Referer_Page: not found
./dp301p_v370_build_18.bin: 8: ./dp301p_v370_build_18.bin: Product: not found
./dp301p_v370_build_18.bin: 9: ./dp301p_v370_build_18.bin: Mac_Address: not found
./dp301p_v370_build_18.bin: 10: ./dp301p_v370_build_18.bin: Model_Name: not found
./dp301p_v370_build_18.bin: 11: ./dp301p_v370_build_18.bin: Sys_Status: not found
./dp301p_v370_build_18.bin: 12: ./dp301p_v370_build_18.bin: BootRom_Ver: not found
./dp301p_v370_build_18.bin: 13: ./dp301p_v370_build_18.bin: Firmware_Ver: not found
./dp301p_v370_build_18.bin: 14: ./dp301p_v370_build_18.bin: SYS_UpTime: not found
./dp301p_v370_build_18.bin: 15: ./dp301p_v370_build_18.bin: Hardware_VER: not found
./dp301p_v370_build_18.bin: 16: ./dp301p_v370_build_18.bin: Release_Date: not found
./dp301p_v370_build_18.bin: 17: ./dp301p_v370_build_18.bin: IP_HEAD: not found
./dp301p_v370_build_18.bin: 18: ./dp301p_v370_build_18.bin: Host_IP: not found
./dp301p_v370_build_18.bin: 19: ./dp301p_v370_build_18.bin: Host_Port: not found
./dp301p_v370_build_18.bin: 20: ./dp301p_v370_build_18.bin: SRV_Name: not found
./dp301p_v370_build_18.bin: 21: ./dp301p_v370_build_18.bin: IP_Address: not found
./dp301p_v370_build_18.bin: 22: ./dp301p_v370_build_18.bin: Subnet_Mask: not found
./dp301p_v370_build_18.bin: 23: ./dp301p_v370_build_18.bin: Subnet_Sel: not found
./dp301p_v370_build_18.bin: 24: ./dp301p_v370_build_18.bin: Sys_Password: not found
./dp301p_v370_build_18.bin: 25: ./dp301p_v370_build_18.bin: SYS_Location: not found
./dp301p_v370_build_18.bin: 26: ./dp301p_v370_build_18.bin: ADM_CONTACT: not found
./dp301p_v370_build_18.bin: 27: ./dp301p_v370_build_18.bin: PS_Portname: not found
./dp301p_v370_build_18.bin: 28: ./dp301p_v370_build_18.bin: PS_Descrip: not found
./dp301p_v370_build_18.bin: 29: ./dp301p_v370_build_18.bin: PS_Speed: not found
./dp301p_v370_build_18.bin: 30: ./dp301p_v370_build_18.bin: PS_PJLPrinter: not found
./dp301p_v370_build_18.bin: 31: ./dp301p_v370_build_18.bin: WPASupport: not found
./dp301p_v370_build_18.bin: 32: ./dp301p_v370_build_18.bin: WL_Mode: not found
./dp301p_v370_build_18.bin: 33: ./dp301p_v370_build_18.bin: ESS_ID: not found
./dp301p_v370_build_18.bin: 34: ./dp301p_v370_build_18.bin: WirelessCountry: not found
./dp301p_v370_build_18.bin: 35: ./dp301p_v370_build_18.bin: WL_Channel: not found
./dp301p_v370_build_18.bin: 36: ./dp301p_v370_build_18.bin: Wep_Enable: not found
./dp301p_v370_build_18.bin: 37: ./dp301p_v370_build_18.bin: WEPEncryWay: not found
./dp301p_v370_build_18.bin: 38: ./dp301p_v370_build_18.bin: WEPKeyLen: not found
./dp301p_v370_build_18.bin: 39: ./dp301p_v370_build_18.bin: Wep_KEYuse: not found
./dp301p_v370_build_18.bin: 40: ./dp301p_v370_build_18.bin: WEPKeySelect: not found
./dp301p_v370_build_18.bin: 41: ./dp301p_v370_build_18.bin: Wep_Encrypt: not found
./dp301p_v370_build_18.bin: 42: ./dp301p_v370_build_18.bin: Wep_Password: not found
./dp301p_v370_build_18.bin: 43: ./dp301p_v370_build_18.bin: Wep_Password1: not found
./dp301p_v370_build_18.bin: 44: ./dp301p_v370_build_18.bin: Wep_Password2: not found
./dp301p_v370_build_18.bin: 45: ./dp301p_v370_build_18.bin: Wep_Password3: not found
./dp301p_v370_build_18.bin: 46: ./dp301p_v370_build_18.bin: Wep_Password4: not found
./dp301p_v370_build_18.bin: 47: ./dp301p_v370_build_18.bin: WL_TXRate: not found
./dp301p_v370_build_18.bin: 48: ./dp301p_v370_build_18.bin: WL_Beacon: not found
./dp301p_v370_build_18.bin: 49: ./dp301p_v370_build_18.bin: WL_Preamble: not found
./dp301p_v370_build_18.bin: 50: ./dp301p_v370_build_18.bin: WL_AuthType: not found
./dp301p_v370_build_18.bin: 51: ./dp301p_v370_build_18.bin: WL_AuthTypeSel: not found
./dp301p_v370_build_18.bin: 52: ./dp301p_v370_build_18.bin: PreSharedKey: not found
./dp301p_v370_build_18.bin: 53: ./dp301p_v370_build_18.bin: WL_ModeVal: not found
./dp301p_v370_build_18.bin: 54: ./dp301p_v370_build_18.bin: WL_ChannelVal: not found
./dp301p_v370_build_18.bin: 55: ./dp301p_v370_build_18.bin: WL_TXRateVal: not found
./dp301p_v370_build_18.bin: 56: ./dp301p_v370_build_18.bin: WL_PreambleVal: not found
./dp301p_v370_build_18.bin: 57: ./dp301p_v370_build_18.bin: WL_AuthTypeVal: not found
./dp301p_v370_build_18.bin: 58: ./dp301p_v370_build_18.bin: Wep_EnableVal: not found
./dp301p_v370_build_18.bin: 59: ./dp301p_v370_build_18.bin: Wep_EncryptVal: not found
./dp301p_v370_build_18.bin: 60: ./dp301p_v370_build_18.bin: Wep_KEYuseVal: not found
./dp301p_v370_build_18.bin: 61: ./dp301p_v370_build_18.bin: WL_Manger: not found
./dp301p_v370_build_18.bin: 62: ./dp301p_v370_build_18.bin: WL_ModeStr: not found
./dp301p_v370_build_18.bin: 63: ./dp301p_v370_build_18.bin: WL_TxPacket: not found
./dp301p_v370_build_18.bin: 64: ./dp301p_v370_build_18.bin: WL_TxError: not found
./dp301p_v370_build_18.bin: 65: ./dp301p_v370_build_18.bin: WL_RxPacket: not found
./dp301p_v370_build_18.bin: 66: ./dp301p_v370_build_18.bin: WL_RxError: not found
./dp301p_v370_build_18.bin: 67: ./dp301p_v370_build_18.bin: WLAN_STATION: not found
./dp301p_v370_build_18.bin: 68: ./dp301p_v370_build_18.bin: Default_Gateway: not found
./dp301p_v370_build_18.bin: 69: ./dp301p_v370_build_18.bin: DNS_IP_Address: not found
./dp301p_v370_build_18.bin: 70: ./dp301p_v370_build_18.bin: Second_Port: not found
./dp301p_v370_build_18.bin: 71: ./dp301p_v370_build_18.bin: Web_Second: not found
./dp301p_v370_build_18.bin: 72: ./dp301p_v370_build_18.bin: IP_ASSIGN: not found
./dp301p_v370_build_18.bin: 73: ./dp301p_v370_build_18.bin: RARP_ASSIGN: not found
./dp301p_v370_build_18.bin: 74: ./dp301p_v370_build_18.bin: BOOTP_ASSIGN: not found
./dp301p_v370_build_18.bin: 75: ./dp301p_v370_build_18.bin: DHCP_ASSIGN: not found
./dp301p_v370_build_18.bin: 76: ./dp301p_v370_build_18.bin: UPnP_Enable: not found
./dp301p_v370_build_18.bin: 77: ./dp301p_v370_build_18.bin: MACRend_Enable: not found
./dp301p_v370_build_18.bin: 78: ./dp301p_v370_build_18.bin: SNMP_Enable: not found
./dp301p_v370_build_18.bin: 79: ./dp301p_v370_build_18.bin: SNMP_Value: not found
./dp301p_v370_build_18.bin: 80: ./dp301p_v370_build_18.bin: SNMP_Name: not found
./dp301p_v370_build_18.bin: 81: ./dp301p_v370_build_18.bin: SNMP_Access: not found
./dp301p_v370_build_18.bin: 82: ./dp301p_v370_build_18.bin: PS_NBGroupname: not found
./dp301p_v370_build_18.bin: 83: ./dp301p_v370_build_18.bin: PS_NBStation: not found
./dp301p_v370_build_18.bin: 84: ./dp301p_v370_build_18.bin: PS_NBSession: not found
./dp301p_v370_build_18.bin: 85: ./dp301p_v370_build_18.bin: PS_AptkEnable: not found
./dp301p_v370_build_18.bin: 86: ./dp301p_v370_build_18.bin: PS_AptkZone: not found
./dp301p_v370_build_18.bin: 87: ./dp301p_v370_build_18.bin: PS_AptkChooser: not found
./dp301p_v370_build_18.bin: 88: ./dp301p_v370_build_18.bin: PS_Aptktype: not found
./dp301p_v370_build_18.bin: 89: ./dp301p_v370_build_18.bin: PS_Aptklevel: not found
./dp301p_v370_build_18.bin: 90: ./dp301p_v370_build_18.bin: PS_Aptkfont: not found
./dp301p_v370_build_18.bin: 91: ./dp301p_v370_build_18.bin: Print_Port: not found
./dp301p_v370_build_18.bin: 92: ./dp301p_v370_build_18.bin: Current_IP: not found
./dp301p_v370_build_18.bin: 93: ./dp301p_v370_build_18.bin: PS_Status: not found
./dp301p_v370_build_18.bin: 94: ./dp301p_v370_build_18.bin: PS_BaudRate: not found
./dp301p_v370_build_18.bin: 95: ./dp301p_v370_build_18.bin: PS_DataBits: not found
./dp301p_v370_build_18.bin: 96: ./dp301p_v370_build_18.bin: PS_StopBits: not found
./dp301p_v370_build_18.bin: 97: ./dp301p_v370_build_18.bin: PS_ParityBits: not found
./dp301p_v370_build_18.bin: 98: ./dp301p_v370_build_18.bin: PS_SWFlow: not found
./dp301p_v370_build_18.bin: 99: ./dp301p_v370_build_18.bin: PS_HWFlow: not found
./dp301p_v370_build_18.bin: 100: ./dp301p_v370_build_18.bin: PrtCNTL_Enable: not found
./dp301p_v370_build_18.bin: 101: ./dp301p_v370_build_18.bin: PrtOTH_Enable: not found
./dp301p_v370_build_18.bin: 102: ./dp301p_v370_build_18.bin: EMAIL_ENABLE: not found
./dp301p_v370_build_18.bin: 103: ./dp301p_v370_build_18.bin: Email_RecvEnable: not found
./dp301p_v370_build_18.bin: 104: ./dp301p_v370_build_18.bin: Email_RecvPort: not found
./dp301p_v370_build_18.bin: 105: ./dp301p_v370_build_18.bin: Email_RCVInterval: not found
./dp301p_v370_build_18.bin: 106: ./dp301p_v370_build_18.bin: Email_POP3: not found
./dp301p_v370_build_18.bin: 107: ./dp301p_v370_build_18.bin: Email_SMTP: not found
./dp301p_v370_build_18.bin: 108: ./dp301p_v370_build_18.bin: Email_RCV: not found
./dp301p_v370_build_18.bin: 109: ./dp301p_v370_build_18.bin: Email_Send: not found
./dp301p_v370_build_18.bin: 110: ./dp301p_v370_build_18.bin: Email_SendUser: not found
./dp301p_v370_build_18.bin: 111: ./dp301p_v370_build_18.bin: Email_SendPass: not found
./dp301p_v370_build_18.bin: 112: ./dp301p_v370_build_18.bin: Email_RCVUser: not found
./dp301p_v370_build_18.bin: 113: ./dp301p_v370_build_18.bin: Email_RCVPass: not found
./dp301p_v370_build_18.bin: 114: ./dp301p_v370_build_18.bin: PS_USBSpeed: not found
./dp301p_v370_build_18.bin: 115: ./dp301p_v370_build_18.bin: PS_LPTSpeed: not found
./dp301p_v370_build_18.bin: 116: ./dp301p_v370_build_18.bin: PS_COMSpeed: not found
./dp301p_v370_build_18.bin: 117: ./dp301p_v370_build_18.bin: PS_TotalJob: not found
./dp301p_v370_build_18.bin: 118: ./dp301p_v370_build_18.bin: PS_TotalSize: not found
./dp301p_v370_build_18.bin: 119: ./dp301p_v370_build_18.bin: PS_CurUser: not found
./dp301p_v370_build_18.bin: 120: ./dp301p_v370_build_18.bin: PS_CurProtocol: not found
./dp301p_v370_build_18.bin: 121: ./dp301p_v370_build_18.bin: PS_CurSpoolSize: not found
./dp301p_v370_build_18.bin: 122: ./dp301p_v370_build_18.bin: PS_CurPrintSize: not found
./dp301p_v370_build_18.bin: 123: ./dp301p_v370_build_18.bin: Ether_Link: not found
./dp301p_v370_build_18.bin: 124: ./dp301p_v370_build_18.bin: Ether_Speed: not found
./dp301p_v370_build_18.bin: 125: ./dp301p_v370_build_18.bin: Ether_Duplex: not found
./dp301p_v370_build_18.bin: 126: ./dp301p_v370_build_18.bin: Ether_TxPacket: not found
./dp301p_v370_build_18.bin: 127: ./dp301p_v370_build_18.bin: Ether_TxError: not found
./dp301p_v370_build_18.bin: 128: ./dp301p_v370_build_18.bin: Ether_RxPacket: not found
./dp301p_v370_build_18.bin: 129: ./dp301p_v370_build_18.bin: Ether_RxError: not found
./dp301p_v370_build_18.bin: 130: ./dp301p_v370_build_18.bin: WL_Link: not found
./dp301p_v370_build_18.bin: 131: ./dp301p_v370_build_18.bin: WLANStatus: not found
./dp301p_v370_build_18.bin: 132: ./dp301p_v370_build_18.bin: WL_CurESSID: not found
./dp301p_v370_build_18.bin: 133: ./dp301p_v370_build_18.bin: WL_CurAPMAC: not found
./dp301p_v370_build_18.bin: 134: ./dp301p_v370_build_18.bin: WL_CurChannel: not found
./dp301p_v370_build_18.bin: 135: ./dp301p_v370_build_18.bin: WL_CurTxRate: not found
./dp301p_v370_build_18.bin: 136: ./dp301p_v370_build_18.bin: WEP_EncryptStr: not found
./dp301p_v370_build_18.bin: 137: ./dp301p_v370_build_18.bin: AUTOIP_Str: not found
./dp301p_v370_build_18.bin: 138: ./dp301p_v370_build_18.bin: DHCP_GOTIP: not found
./dp301p_v370_build_18.bin: 139: ./dp301p_v370_build_18.bin: UPNP_Str: not found
./dp301p_v370_build_18.bin: 140: ./dp301p_v370_build_18.bin: UPNP_Value: not found
./dp301p_v370_build_18.bin: 141: ./dp301p_v370_build_18.bin: UPNP_GOTIP: not found
./dp301p_v370_build_18.bin: 142: ./dp301p_v370_build_18.bin: MAC_Renezvous: not found
./dp301p_v370_build_18.bin: 143: ./dp301p_v370_build_18.bin: MACREND_Value: not found
./dp301p_v370_build_18.bin: 144: ./dp301p_v370_build_18.bin: MACREND_GOTIP: not found
./dp301p_v370_build_18.bin: 145: ./dp301p_v370_build_18.bin: PS_ProtoStatus: not found
./dp301p_v370_build_18.bin: 146: ./dp301p_v370_build_18.bin: PS_ProtoTTJob: not found
./dp301p_v370_build_18.bin: 147: ./dp301p_v370_build_18.bin: PS_ProtoTTSize: not found
./dp301p_v370_build_18.bin: 148: ./dp301p_v370_build_18.bin: UserSts_List: not found
./dp301p_v370_build_18.bin: 149: ./dp301p_v370_build_18.bin: PrintUser_List: not found
./dp301p_v370_build_18.bin: 150: ./dp301p_v370_build_18.bin: PrintUser_Table: not found
./dp301p_v370_build_18.bin: 151: ./dp301p_v370_build_18.bin: TotalUsers: not found
./dp301p_v370_build_18.bin: 152: ./dp301p_v370_build_18.bin: ESSID_List: not found
./dp301p_v370_build_18.bin: 153: ./dp301p_v370_build_18.bin: PS_Manufacturer: not found
./dp301p_v370_build_18.bin: 154: ./dp301p_v370_build_18.bin: PS_Model: not found
./dp301p_v370_build_18.bin: 155: ./dp301p_v370_build_18.bin: PS_CMDSet: not found
./dp301p_v370_build_18.bin: 156: ./dp301p_v370_build_18.bin: WZ_SRVName: not found
./dp301p_v370_build_18.bin: 157: ./dp301p_v370_build_18.bin: WZ_Portname: not found
./dp301p_v370_build_18.bin: 158: ./dp301p_v370_build_18.bin: WZ_Password: not found
./dp301p_v370_build_18.bin: 159: ./dp301p_v370_build_18.bin: WZ_IPASSIGN: not found
./dp301p_v370_build_18.bin: 160: ./dp301p_v370_build_18.bin: WZ_IPAddress: not found
./dp301p_v370_build_18.bin: 161: ./dp301p_v370_build_18.bin: WZ_Subnet: not found
./dp301p_v370_build_18.bin: 162: ./dp301p_v370_build_18.bin: WZ_Gateway: not found
./dp301p_v370_build_18.bin: 163: ./dp301p_v370_build_18.bin: WZ_NBGroupname: not found
./dp301p_v370_build_18.bin: 164: ./dp301p_v370_build_18.bin: WZ_SecondPort: not found
./dp301p_v370_build_18.bin: 165: ./dp301p_v370_build_18.bin: WZ_WebSecond: not found
./dp301p_v370_build_18.bin: 166: ./dp301p_v370_build_18.bin: WZ_IPAddrStr: not found
./dp301p_v370_build_18.bin: 167: ./dp301p_v370_build_18.bin: WZ_SubnetStr: not found
./dp301p_v370_build_18.bin: 168: ./dp301p_v370_build_18.bin: WZ_GatewayStr: not found
./dp301p_v370_build_18.bin: 169: ./dp301p_v370_build_18.bin: WZ_SecPortStr: not found
./dp301p_v370_build_18.bin: 170: ./dp301p_v370_build_18.bin: WZ_IPASSIGNVal: not found
./dp301p_v370_build_18.bin: 171: ./dp301p_v370_build_18.bin: WZ_SecondPortVal: not found
./dp301p_v370_build_18.bin: 172: ./dp301p_v370_build_18.bin: USBPortList: not found
./dp301p_v370_build_18.bin: 173: ./dp301p_v370_build_18.bin: USBMode: not found
./dp301p_v370_build_18.bin: 174: ./dp301p_v370_build_18.bin: USBControlStatus: not found
./dp301p_v370_build_18.bin: 175: ./dp301p_v370_build_18.bin: DownstreamDevice: not found
./dp301p_v370_build_18.bin: 176: ./dp301p_v370_build_18.bin: DownstreamControl: not found
./dp301p_v370_build_18.bin: 177: ./dp301p_v370_build_18.bin: PrintOutMode: not found
./dp301p_v370_build_18.bin: 178: ./dp301p_v370_build_18.bin: ReportMessage: not found
./dp301p_v370_build_18.bin: 179: ./dp301p_v370_build_18.bin: lPRINT: not found
./dp301p_v370_build_18.bin: 180: ./dp301p_v370_build_18.bin: EMAIL_TEST: not found
./dp301p_v370_build_18.bin: 181: ./dp301p_v370_build_18.bin: EMAIL_RECV: not found
./dp301p_v370_build_18.bin: 182: ./dp301p_v370_build_18.bin: USBTest: not found
./dp301p_v370_build_18.bin: 183: ./dp301p_v370_build_18.bin: DownstreamEnumerate: not found
./dp301p_v370_build_18.bin: 184: ./dp301p_v370_build_18.bin: DownstreamExecute: not found
./dp301p_v370_build_18.bin: 185: ./dp301p_v370_build_18.bin: Config1: not found
./dp301p_v370_build_18.bin: 186: ./dp301p_v370_build_18.bin: Config2: not found
./dp301p_v370_build_18.bin: 187: ./dp301p_v370_build_18.bin: Config2Adv: not found
./dp301p_v370_build_18.bin: 188: ./dp301p_v370_build_18.bin: Config3: not found
./dp301p_v370_build_18.bin: 189: ./dp301p_v370_build_18.bin: Config3Add: not found
./dp301p_v370_build_18.bin: 190: ./dp301p_v370_build_18.bin: Config3Del: not found
./dp301p_v370_build_18.bin: 191: ./dp301p_v370_build_18.bin: Config4: not found
./dp301p_v370_build_18.bin: 192: ./dp301p_v370_build_18.bin: Config5: not found
./dp301p_v370_build_18.bin: 193: ./dp301p_v370_build_18.bin: Config6: not found
./dp301p_v370_build_18.bin: 194: ./dp301p_v370_build_18.bin: ConfigA: not found
./dp301p_v370_build_18.bin: 195: ./dp301p_v370_build_18.bin: Reset: not found
./dp301p_v370_build_18.bin: 196: ./dp301p_v370_build_18.bin: Factory: not found
./dp301p_v370_build_18.bin: 197: ./dp301p_v370_build_18.bin: APRefresh: not found
./dp301p_v370_build_18.bin: 198: ./dp301p_v370_build_18.bin: RefreshTime: not found
./dp301p_v370_build_18.bin: 199: ./dp301p_v370_build_18.bin: EntryNo: not found
./dp301p_v370_build_18.bin: 200: ./dp301p_v370_build_18.bin: SRV_Name: not found
./dp301p_v370_build_18.bin: 201: ./dp301p_v370_build_18.bin: IP_Address: not found
./dp301p_v370_build_18.bin: 202: ./dp301p_v370_build_18.bin: Subnet_Mask: not found
./dp301p_v370_build_18.bin: 203: ./dp301p_v370_build_18.bin: Subnet_Sel: not found
./dp301p_v370_build_18.bin: 204: ./dp301p_v370_build_18.bin: Check_CurPassword: not found
./dp301p_v370_build_18.bin: 205: ./dp301p_v370_build_18.bin: Sys_Password: not found
./dp301p_v370_build_18.bin: 206: ./dp301p_v370_build_18.bin: Verify_Password: not found
./dp301p_v370_build_18.bin: 207: ./dp301p_v370_build_18.bin: SYS_Location: not found
./dp301p_v370_build_18.bin: 208: ./dp301p_v370_build_18.bin: ADM_CONTACT: not found
./dp301p_v370_build_18.bin: 209: ./dp301p_v370_build_18.bin: PS_Portname: not found
./dp301p_v370_build_18.bin: 210: ./dp301p_v370_build_18.bin: PS_Descrip: not found
./dp301p_v370_build_18.bin: 211: ./dp301p_v370_build_18.bin: PS_Speed: not found
./dp301p_v370_build_18.bin: 212: ./dp301p_v370_build_18.bin: PS_PJLPrinter: not found
./dp301p_v370_build_18.bin: 213: ./dp301p_v370_build_18.bin: WL_Mode: not found
./dp301p_v370_build_18.bin: 214: ./dp301p_v370_build_18.bin: ESS_ID: not found
./dp301p_v370_build_18.bin: 215: ./dp301p_v370_build_18.bin: ESSID_SEL: not found
./dp301p_v370_build_18.bin: 216: ./dp301p_v370_build_18.bin: WirelessCountry: not found
./dp301p_v370_build_18.bin: 217: ./dp301p_v370_build_18.bin: WL_Channel: not found
./dp301p_v370_build_18.bin: 218: ./dp301p_v370_build_18.bin: Wep_Enable: not found
./dp301p_v370_build_18.bin: 219: ./dp301p_v370_build_18.bin: Wep_KEYuse: not found
./dp301p_v370_build_18.bin: 220: ./dp301p_v370_build_18.bin: WEPKeySelect: not found
./dp301p_v370_build_18.bin: 221: ./dp301p_v370_build_18.bin: Wep_Encrypt: not found
./dp301p_v370_build_18.bin: 222: ./dp301p_v370_build_18.bin: Wep_Password: not found
./dp301p_v370_build_18.bin: 223: ./dp301p_v370_build_18.bin: Wep_Password1: not found
./dp301p_v370_build_18.bin: 224: ./dp301p_v370_build_18.bin: Wep_Password2: not found
./dp301p_v370_build_18.bin: 225: ./dp301p_v370_build_18.bin: Wep_Password3: not found
./dp301p_v370_build_18.bin: 226: ./dp301p_v370_build_18.bin: Wep_Password4: not found
./dp301p_v370_build_18.bin: 227: ./dp301p_v370_build_18.bin: Verify_Wep: not found
./dp301p_v370_build_18.bin: 228: ./dp301p_v370_build_18.bin: WL_TXRate: not found
./dp301p_v370_build_18.bin: 229: ./dp301p_v370_build_18.bin: WL_Beacon: not found
./dp301p_v370_build_18.bin: 230: ./dp301p_v370_build_18.bin: WL_Preamble: not found
./dp301p_v370_build_18.bin: 231: ./dp301p_v370_build_18.bin: WL_AuthType: not found
./dp301p_v370_build_18.bin: 232: ./dp301p_v370_build_18.bin: WL_AuthTypeSel: not found
./dp301p_v370_build_18.bin: 233: ./dp301p_v370_build_18.bin: PreSharedKey: not found
./dp301p_v370_build_18.bin: 234: ./dp301p_v370_build_18.bin: User_Name: not found
./dp301p_v370_build_18.bin: 235: ./dp301p_v370_build_18.bin: User_MAC: not found
./dp301p_v370_build_18.bin: 236: ./dp301p_v370_build_18.bin: MAC_ACCESS: not found
./dp301p_v370_build_18.bin: 237: ./dp301p_v370_build_18.bin: DeleteOneMac: not found
./dp301p_v370_build_18.bin: 238: ./dp301p_v370_build_18.bin: Default_Gateway: not found
./dp301p_v370_build_18.bin: 239: ./dp301p_v370_build_18.bin: DNS_IP_Address: not found
./dp301p_v370_build_18.bin: 240: ./dp301p_v370_build_18.bin: Second_Port: not found
./dp301p_v370_build_18.bin: 241: ./dp301p_v370_build_18.bin: Web_Second: not found
./dp301p_v370_build_18.bin: 242: ./dp301p_v370_build_18.bin: IP_ASSIGN: not found
./dp301p_v370_build_18.bin: 243: ./dp301p_v370_build_18.bin: RARP_ASSIGN: not found
./dp301p_v370_build_18.bin: 244: ./dp301p_v370_build_18.bin: BOOTP_ASSIGN: not found
./dp301p_v370_build_18.bin: 245: ./dp301p_v370_build_18.bin: DHCP_ASSIGN: not found
./dp301p_v370_build_18.bin: 246: ./dp301p_v370_build_18.bin: UPnP_Enable: not found
./dp301p_v370_build_18.bin: 247: ./dp301p_v370_build_18.bin: MACRend_Enable: not found
./dp301p_v370_build_18.bin: 248: ./dp301p_v370_build_18.bin: SNMP_Enable: not found
./dp301p_v370_build_18.bin: 249: ./dp301p_v370_build_18.bin: SNMP_Name: not found
./dp301p_v370_build_18.bin: 250: ./dp301p_v370_build_18.bin: SNMP_Access: not found
./dp301p_v370_build_18.bin: 251: ./dp301p_v370_build_18.bin: PS_NBGroupname: not found
./dp301p_v370_build_18.bin: 252: ./dp301p_v370_build_18.bin: PS_NBStation: not found
./dp301p_v370_build_18.bin: 253: ./dp301p_v370_build_18.bin: PS_NBSession: not found
./dp301p_v370_build_18.bin: 254: ./dp301p_v370_build_18.bin: PS_AptkEnable: not found
./dp301p_v370_build_18.bin: 255: ./dp301p_v370_build_18.bin: PS_AptkZone: not found
./dp301p_v370_build_18.bin: 256: ./dp301p_v370_build_18.bin: PS_Aptktype: not found
./dp301p_v370_build_18.bin: 257: ./dp301p_v370_build_18.bin: PS_Aptklevel: not found
./dp301p_v370_build_18.bin: 258: ./dp301p_v370_build_18.bin: PS_Aptkfont: not found
./dp301p_v370_build_18.bin: 259: ./dp301p_v370_build_18.bin: Print_Port: not found
./dp301p_v370_build_18.bin: 260: ./dp301p_v370_build_18.bin: PS_BaudRate: not found
./dp301p_v370_build_18.bin: 261: ./dp301p_v370_build_18.bin: PS_DataBits: not found
./dp301p_v370_build_18.bin: 262: ./dp301p_v370_build_18.bin: PS_StopBits: not found
./dp301p_v370_build_18.bin: 263: ./dp301p_v370_build_18.bin: PS_ParityBits: not found
./dp301p_v370_build_18.bin: 264: ./dp301p_v370_build_18.bin: PS_SWFlow: not found
./dp301p_v370_build_18.bin: 265: ./dp301p_v370_build_18.bin: PS_HWFlow: not found
./dp301p_v370_build_18.bin: 266: ./dp301p_v370_build_18.bin: PrtCNTL_Enable: not found
./dp301p_v370_build_18.bin: 267: ./dp301p_v370_build_18.bin: PrtOTH_Enable: not found
./dp301p_v370_build_18.bin: 268: ./dp301p_v370_build_18.bin: EMAIL_ENABLE: not found
./dp301p_v370_build_18.bin: 269: ./dp301p_v370_build_18.bin: Email_RecvEnable: not found
./dp301p_v370_build_18.bin: 270: ./dp301p_v370_build_18.bin: Email_RecvPort: not found
./dp301p_v370_build_18.bin: 271: ./dp301p_v370_build_18.bin: Email_RCVInterval: not found
./dp301p_v370_build_18.bin: 272: ./dp301p_v370_build_18.bin: Email_POP3: not found
./dp301p_v370_build_18.bin: 273: ./dp301p_v370_build_18.bin: Email_SMTP: not found
./dp301p_v370_build_18.bin: 274: ./dp301p_v370_build_18.bin: Email_RCV: not found
./dp301p_v370_build_18.bin: 275: ./dp301p_v370_build_18.bin: Email_Send: not found
./dp301p_v370_build_18.bin: 276: ./dp301p_v370_build_18.bin: Email_SendUser: not found
./dp301p_v370_build_18.bin: 277: ./dp301p_v370_build_18.bin: Email_SendPass: not found
./dp301p_v370_build_18.bin: 278: ./dp301p_v370_build_18.bin: Email_RCVUser: not found
./dp301p_v370_build_18.bin: 279: ./dp301p_v370_build_18.bin: Email_RCVPass: not found
./dp301p_v370_build_18.bin: 280: ./dp301p_v370_build_18.bin: WepPage: not found
./dp301p_v370_build_18.bin: 281: ./dp301p_v370_build_18.bin: USBPortNumber: not found
./dp301p_v370_build_18.bin: 282: ./dp301p_v370_build_18.bin: USBMode: not found
./dp301p_v370_build_18.bin: 283: ./dp301p_v370_build_18.bin: DownstreamsDevice: not found
./dp301p_v370_build_18.bin: 284: ./dp301p_v370_build_18.bin: DownstreamControl: not found
./dp301p_v370_build_18.bin: 285: ./dp301p_v370_build_18.bin: PrintOutMode: not found
./dp301p_v370_build_18.bin: 286: ./dp301p_v370_build_18.bin: ReportMessage: not found
./dp301p_v370_build_18.bin: 287: ./dp301p_v370_build_18.bin: m100: not found
./dp301p_v370_build_18.bin: 288: ./dp301p_v370_build_18.bin: r: not found
./dp301p_v370_build_18.bin: 289: ./dp301p_v370_build_18.bin: 101: not found
./dp301p_v370_build_18.bin: 290: ./dp301p_v370_build_18.bin: 200: not found
./dp301p_v370_build_18.bin: 291: ./dp301p_v370_build_18.bin: LEVEL_200: not found
./dp301p_v370_build_18.bin: 292: ./dp301p_v370_build_18.bin: 201: not found
./dp301p_v370_build_18.bin: 293: ./dp301p_v370_build_18.bin: 202: not found
./dp301p_v370_build_18.bin: 294: ./dp301p_v370_build_18.bin: 203: not found
./dp301p_v370_build_18.bin: 295: ./dp301p_v370_build_18.bin: 204: not found
./dp301p_v370_build_18.bin: 296: ./dp301p_v370_build_18.bin: 205: not found
./dp301p_v370_build_18.bin: 297: ./dp301p_v370_build_18.bin: 206: not found
./dp301p_v370_build_18.bin: 298: ./dp301p_v370_build_18.bin: 300: not found
: not found70_build_18.bin: 299: ./dp301p_v370_build_18.bin: 9
./dp301p_v370_build_18.bin: 300: ./dp301p_v370_build_18.bin: 301: not found
./dp301p_v370_build_18.bin: 301: ./dp301p_v370_build_18.bin: 302: not found
./dp301p_v370_build_18.bin: 302: ./dp301p_v370_build_18.bin: 303: not found
./dp301p_v370_build_18.bin: 303: ./dp301p_v370_build_18.bin: 304: not found
./dp301p_v370_build_18.bin: 304: ./dp301p_v370_build_18.bin: 305: not found
./dp301p_v370_build_18.bin: 305: ./dp301p_v370_build_18.bin: 400: not found
: not found70_build_18.bin: 306: ./dp301p_v370_build_18.bin: 15
./dp301p_v370_build_18.bin: 307: ./dp301p_v370_build_18.bin: 401: not found
./dp301p_v370_build_18.bin: 308: ./dp301p_v370_build_18.bin: 402: not found
./dp301p_v370_build_18.bin: 309: ./dp301p_v370_build_18.bin: 403: not found
./dp301p_v370_build_18.bin: 310: ./dp301p_v370_build_18.bin: 404: not found
./dp301p_v370_build_18.bin: 311: ./dp301p_v370_build_18.bin: 405: not found
./dp301p_v370_build_18.bin: 312: ./dp301p_v370_build_18.bin: 406: not found
./dp301p_v370_build_18.bin: 313: ./dp301p_v370_build_18.bin: 407: not found
./dp301p_v370_build_18.bin: 314: ./dp301p_v370_build_18.bin: 408: not found
./dp301p_v370_build_18.bin: 315: ./dp301p_v370_build_18.bin: 409: not found
./dp301p_v370_build_18.bin: 316: ./dp301p_v370_build_18.bin: 410: not found
./dp301p_v370_build_18.bin: 317: ./dp301p_v370_build_18.bin: 411: not found
./dp301p_v370_build_18.bin: 318: ./dp301p_v370_build_18.bin: 412: not found
./dp301p_v370_build_18.bin: 319: ./dp301p_v370_build_18.bin: 413: not found
./dp301p_v370_build_18.bin: 320: ./dp301p_v370_build_18.bin: 414: not found
./dp301p_v370_build_18.bin: 321: ./dp301p_v370_build_18.bin: 415: not found
./dp301p_v370_build_18.bin: 322: ./dp301p_v370_build_18.bin: 500: not found
: not found70_build_18.bin: 323: ./dp301p_v370_build_18.bin: 31
./dp301p_v370_build_18.bin: 324: ./dp301p_v370_build_18.bin: 501: not found
./dp301p_v370_build_18.bin: 325: ./dp301p_v370_build_18.bin: 502: not found
./dp301p_v370_build_18.bin: 326: ./dp301p_v370_build_18.bin: 503: not found
./dp301p_v370_build_18.bin: 327: ./dp301p_v370_build_18.bin: 504: not found
./dp301p_v370_build_18.bin: 328: ./dp301p_v370_build_18.bin: 505: not found
./dp301p_v370_build_18.bin: 329: ./dp301p_v370_build_18.bin: 506: not found
./dp301p_v370_build_18.bin: 330: ./dp301p_v370_build_18.bin: %%: not found
./dp301p_v370_build_18.bin: 331: ./dp301p_v370_build_18.bin: ine: not found
./dp301p_v370_build_18.bin: 333: ./dp301p_v370_build_18.bin: Authorization: not found
./dp301p_v370_build_18.bin: 334: ./dp301p_v370_build_18.bin: Basic: not found
./dp301p_v370_build_18.bin: 335: ./dp301p_v370_build_18.bin: WWW-Authenticate:: not found
./dp301p_v370_build_18.bin: 336: ./dp301p_v370_build_18.bin: Allow:: not found
./dp301p_v370_build_18.bin: 337: ./dp301p_v370_build_18.bin: Content-Type: not found
./dp301p_v370_build_18.bin: 338: ./dp301p_v370_build_18.bin: Content-Length: not found
./dp301p_v370_build_18.bin: 339: ./dp301p_v370_build_18.bin: Not: not found
./dp301p_v370_build_18.bin: 341: ./dp301p_v370_build_18.bin: Syntax error: newline unexpected
