Can anyone tell me the recommended DPI for a 1080p screen
Thanks all!!
Hi @smartnoise, The basic concept is to match your monitor. 1080 is the vertical pixel (dot) resolution so if the screen area is 11.25 inches high:
1080 dots / 11.25 inches = 96 dpi
Of course, your monitor may not be 11.25 inches so adjust accordingly. The default should have been close to actual.
Thanks, it’s a TV flat screen, 96 DPI gives minute fonts, unreadable, should have explained that, sorry…
You can check some DPI calculator like this one to get the theorically good value for your screen.
Or simply use a DPI your eyes find pleasant.
What’s the size of the screen (in inches)?
35 inch TV dimensions Height: 17.1 inch, Width: 30.4 inch
