Is there a way to remove the drawer arrows, as circled in the screenshot?
Things I have tried so far:
- profuse and excessive googling
- dconf-editor - this appeared to be promising, as there exists the "has arrow" option in the menu for each panel component, but it does not appear to do anything, or I'm misunderstanding its intent, or yet another possibility, there's a way to "refresh" the panel item after I set this option so it reloads somehow?
- mate-tweak
- Searching for the arrow graphic in my theme so I can replace it with a blank transparent png/svg. I don't think it's in there, but if anyone knows where it is please tell me!
Thank you very much for your time and assistance!
