I think I found out why I can not see a directory.
I do not think dev/sda2 is being mounted.
I saw in gparted that it has no mountpoint.
Is that required?
The line before the swapfile is my attempt at fixing that.
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sda1 during installation
UUID=81353260-b5a5-4b72-9fce-432e7c620fdc / ext4 errors=remount-ro 0 1
UUID=b3b0f384-9e2e-45f5-8995-932f1113f59d /media/storagedrive/ ext3 defaults 0
#/dev/sdb2: LABEL="MAXTOR_SDB2" UUID="e0dadb1c-0161-4862-8e95-7c42d8f7fb03" SEC_TYPE="ext2" TYPE="ext3" PARTUUID="000f0791-02"
UUID=e0dadb1c-0161-4862-8e95-7c42d8f7fb03 /media/andy/MAXTOR_SDB2 ext3 defaults 0
# This aint working.
#UUID=5b4b2ae5-9aaa-4559-9f41-afb313998c75 ext4 defaults 0
# /swapfile none swap sw 0 0
