Hello I am having some difficulty working out how to install the driver for this wireless adapter. Does anybody have any advice or experience with this? I’m on AM64, latest version if that helps.
I use a pair of TP link adapters. No software required for mine. you just connect one to the router and mains and another to the pc and mains. Then press the pairing button on the router’s TP link adapter, Then, within two minutes, press the pairing button on the PC’s TP link adapter.
That’s it. You should then have full ethernet access to your router and on out to your network and the internet.
