Hi, i have this network:
Three FritzBox Routers. The first 7490 connected to ISP and has DHCP. The second 7390 works as WiFi access point (DHCP and firewall are disabled). The third 4020 is Guest Wifi.
Raspberry Pi 2 connected to 7390, got the IP from 7490, but can ping only 7390. If i connect Raspberry Pi 2 to 7490 - it works, if i connect Raspberry Pi 2 to 4020 - it works as well.
If i connect Raspberry Pi 2 to 7390 via cable - it works. Now i would like to change USB-WiFi card. The new one is Netgear A6200. I'm trying to install drivers, but i can't:
apt-get install ndisgtk
Reading package lists... Done
Building dependency tree
E: Unable to locate package ndisgtk
How i can install Netgear drivers?
I have other devices connected to 7390 (like Laptop with IP 192.168.29.56) - they are working without any problems.
Thank you.
