I’ve just done a clean install of Windows 10 onto one SSD and then installed Ubuntu Mate 24.04.3LTS onto a 2nd SSD, with Grub also on the 2nd SSD. ( I used the 3rd custom install option on the installation media)
I had seen comments saying this approach is safer/more retrievable, than a dual boot single SSD setup, should grub get corrupted. The Install worked, with Grub as the default boot and both OS options booted up from the grub menu. It also worked with secure boot back on. However, I then tried changing the boot order in the UEFI setup/boot menu. With Windows at top of list and it booted to windows without the grub menu ( as expected)…..
…..but when I returned the order to Ubuntu at top of the boot menu…it still booted to Windows. I presume Grub is corrupted or it is not now in the right place to be found?? ( I am a novice…so I’m guessing)
Should it be possible to change the boot order without damaging grub?
(I have reinstalled Ubuntu Mate and the dual boot set up is working again….. I am happy with how it works…..but at some point I presume I will want to change the boot order …e.g if I need to repair/reinstall windows)
