How can I set dual panels on a dual screens. Just like in ubuntu and windows mirrored panel is set to auto detect.
which version of UM are you using and what graphics card(s) do you?:
VGA Controller: Intel Corporation 3rd Gen Core processor DRAM Controller (rev 09)
UM : 16.04
Thank you for your response Wolfman.
Are you sorted now @Danilo_B_Matias_Jr ?.
Thank you very much for your help wolfman.
Hi Danilo,
please mark as solved so it helps others with the same problem!. (Put a tick in the box on the best answer!).
