You can add speech recognition to Ubuntu with the Uberi Speech Recognition program on Github. The link is https://github.com/Uberi/speech_recognition. Clone the github to view the source and learn how to use this excellent program as a starting point for your own speech to text applications. Make sure your microphone is plugged in and working.
I make a directory called code off my home directory, cd there, and use that as my base.
cd ~
mkdir code
cd code
git clone https://github.com/Uberi/speech_recognition.git
You can compile this after installing all the dependencies or just do the procedure below to make it easy.
cd ~/code
git clone https://git.assembla.com/portaudio.git
cd portaudio/
sudo apt install libasound-dev
./configure
make
sudo make install
cd ~/code
git clone https://github.com/jleb/pyaudio.git
cd pyaudio/
python setup.py install
pip install --upgrade pyaudio
pip install SpeechRecognition
python -m speech_recognition
Now start talking!
BTW, an excellent project would be to convert open assistant to use this superior speech recognition. Open Assistant currently uses blather which doesn’t seem to work on Ubuntu. It should be an easy port. https://github.com/vavrek/Open-Assistant
