Easy tether network issues on 16.04 64 bit
I recently installed easytether because I won’t have wifi once I finish moving and I’m currently unable to connect to the internet using easytether. I’m a novice at dealing with technical issues like this the only thing I found online has to do with 15.04 Ubuntu having a similar issue. The fix for it was this I’m certain that I might need to tweak this fix, but I’m not sure how any help you can give me would be appreciated.
  1. Open the dhclient configuration file for editing
sudo gedit /etc/dhcp/dhclient.conf
2)Add the easytether-tap hard coded DNS
prepend domain-name-servers 192.168.117.1/24
save and close file, restart machine
Nothing happened, still not working but the process is running.
easytet+ 1867 0.0 0.0 19408 2516 ? Ss 10:19 0:00 /usr/bin/easytether-usb -d /sys/devices/pci0000:00/0000:00:1d.7/usb2/2-2/2-2:1.3
Android smartphones nowadays, but i believe Windows and Apple also, does have a built-in feature for the tethering, if you dont’have internet and you need to use it from USIM card provider.
If you have a Wi-Fi routeryou can directly drag the signal by microusb cable,. The OS gets it as an ethernet connection.
The second matter works as a range extender and it is better than internal or external devices.
