I have installed the eclipse from software center. There is no issue while installation.
But when I launched the application, it throwed below error.Seems that it requires oracle JDK.
Could any one help me resolve below error:
!SESSION 2016-02-11 22:25:56.626 -----------------------------------------------
eclipse.buildId=debbuild
java.version=1.8.0_131
java.vendor=Oracle Corporation
BootLoader constants: OS=linux, ARCH=arm, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk
!ENTRY org.eclipse.osgi 4 0 2016-02-11 22:25:59.346
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.osgi.framework.internal.core.SystemBundleActivator.start() of bundle org.eclipse.osgi.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.InternalSystemBundle.resume(InternalSystemBundle.java:225)
at org.eclipse.osgi.framework.internal.core.Framework.launch(Framework.java:656)
at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:274)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:176)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: java.lang.IllegalStateException: Expected to find an object at table index: 728224059
at org.eclipse.osgi.internal.resolver.StateReader.getFromObjectTable(StateReader.java:83)
at org.eclipse.osgi.internal.resolver.StateReader.readBundleDescriptionLazyData(StateReader.java:262)
at org.eclipse.osgi.internal.resolver.StateReader.fullyLoad(StateReader.java:823)
at org.eclipse.osgi.internal.resolver.BundleDescriptionImpl.loadLazyData(BundleDescriptionImpl.java:662)
at org.eclipse.osgi.internal.resolver.BundleDescriptionImpl.getExportPackages(BundleDescriptionImpl.java:160)
at org.eclipse.osgi.framework.internal.core.PackageAdminImpl.setFrameworkVersion(PackageAdminImpl.java:706)
at org.eclipse.osgi.framework.internal.core.PackageAdminImpl.setResolvedBundles(PackageAdminImpl.java:656)
at org.eclipse.osgi.framework.internal.core.SystemBundleActivator.start(SystemBundleActivator.java:67)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
... 13 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2016-02-11 22:25:59.374
!MESSAGE Startup error
!STACK 1
java.lang.RuntimeException: Exception in org.eclipse.osgi.framework.internal.core.SystemBundleActivator.start() of bundle org.eclipse.osgi.
at org.eclipse.osgi.framework.internal.core.InternalSystemBundle.resume(InternalSystemBundle.java:233)
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.osgi.framework.internal.core.SystemBundleActivator.start() of bundle org.eclipse.osgi.
... 11 more
... 13 more
